P0137 – Heated oxygen sensor (HO2S) / oxgen sensor (O2S) 2, bank 1 -low voltage
Last Updated 2016-07-05
P0137 | Heated oxygen sensor (HO2S) 2, bank 1 -low voltage (Buy Part On Amazon) | Exhaust leak, wiring short to earth, H025, ECM |
What Does Code P0137 Mean?
- DTC P0137 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2 (B1S2)
What are the common causes of code P0137 ?
Depending on year, make, and model, DTC P0137 may have number of causes. Here are some of the most common.
What are the symptoms of code P0137 ?
How do you troubleshoot code P0137 ?
Codes Related to P0137
Mám problém s chekem u Chevroletu Svého, který se rozsvítí po 30-50kilometrech od vymazání.Na autě se měnila sonda za katalyzátorem a vlnovec,poraďte jak závadu odstranit?
I have a generic code PO137, the check engine light is lit and the CSV button and ABS icon are flashing. My question is there a common wiring connection that would help me trace any ground fault common to the two. Tnx in advance.
Bud
2010 Toyota Matrix S 2.4 engine.
