P0135 – Heated oxygen sensor (HO2S) 1, bank 1, heater control – circuit malfunction
Avatar photo
By Mia (Contact Me)
Last Updated 2018-02-25
P0135 Heated oxygen sensor (HO2S) 1, bank 1, heater control circuit malfunction
Fuse, wiring, H025, ECM
Where is the Oxygen Sensor? See our guide to the Oxygen Sensor – what it does, where it sits on the engine and how it fails.
  1. What Does Code P0135 Mean?
  2. What are the common causes of code P0135 ?
  3. What are the symptoms of code P0135 ?
  4. How do you troubleshoot code P0135 ?
  5. Codes Related to P0135
  6. Get Help with P0135
The upstream oxygen sensor (O2S) is located ahead of the catalytic converter. It is used to determine the concentration of oxygen in the exhaust gas. This information is used by the PCM to control the engine air/fuel mixture. The sensor compares amount of oxygen in the exhaust to the surrounding air (there is an opening in the sensor that is exposed to the atmosphere). It generates a corresponding voltage which is transmitted to the PCM. The PCM then controls injector pulse based on this value.
Modern vehicles use a heated oxygen sensor (HO2S). These sensors contain a heating element that brings the sensor to operating temperature faster. This allows the PCM to use the signals input sooner, for more precise fuel control and reduced emissions. The heater circuit is energized through a relay that closes when the engine is cranked. The PCM monitors the heater circuit and will turn on the check engine light if it finds a problem.
Code P0135 stands for Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1). This indicates the PCM has detected a problem with the bank 1 oxygen sensor. Bank 1 refers to the side of the engine that has the #1 cylinder. Bank 2 is the opposite side of the engine. If you’ve got a four-cylinder, there will only be one bank.
HO2S
A typical heated oxygen sensor
(Courtesy: easterncatalytic.com)
To sum things up, the common causes for code P0135 are as follows:
  • Problem on the ground side of the O2 sensor heater circuit
  • Problem on the power side of the O2 sensor heater circuit
  • O2 sensor heater element has high resistance
  • O2 sensor heater element has an open circuit
In theory, a failed O2 heater will result in poor fuel economy. But you’ll probably never notice the difference during operation. The only thing you will notice is an illuminated check engine light on your dashboard. If your registration is due, you will also fail the emissions test.
Circuit diagram and connector pinout table for the heated oxygen sensors, listing which terminal carries the heater supply, ground and signal
(Courtesy: alldata.com)
  • Test the heater circuit wiring
  • Test the sensor heating element
Line drawing of a meter connected across an oxygen sensor heater circuit to check it against battery voltage
(Courtesy: 2carpros.com)
Code P0155 is the most closely related code to P0135. It stands for 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1). So, it is essentially the same code, but for the opposite bank of the engine. All of the same diagnostic steps apply.
Reading P0135 on your car
A basic adapter will show you P0135, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
