P0132 – Heated oxygen sensor (HO2S) / oxgen sensor (O2S) 1, bank 1 -high voltage
Last Updated 2016-07-05
P0132 | Heated oxygen sensor (HO2S) 1, bank 1 -high voltage | Wiring short to positive, H025, ECM |
What Does Code P0132 Mean?
- DTC P0132 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1 (B1S1)
What are the common causes of code P0132 ?
Depending on year, make, and model, DTC P0132 may have number of causes. Here are some of the most common.
What are the symptoms of code P0132 ?
How do you troubleshoot code P0132 ?
Codes Related to P0132
BAT Team Discussions for P0132
- Civic 2002 Power Loss P1298
2002 Honda Civic 38k miles and I don't drive it too hard. Maintenance has been kept up with. Sparkplugs are new last summer, injector cleaner added to fuel as well as the water remover Heet. . Since the winter time I have had a problem with engine power when driving after the car has been idle for s... - P0132, P0138, P0888 + etc 1999 Jeep GC Limited
1999 Jeep Grand Cherokee Limited V8 - 4. 7L - 4WD - automatic transmission non-California vehicle over 98,000 miles has alarm system that uses horn and lights purchased this vehicle used about 2 years I recently changed both speed sensors & my Jeep's transmission filters [added correct mopar ATF &... - 02 Liberty trouble codes and cooling issue
2002 jeep liberty sport 3.7L 115,000 miles had bank 1 sensor 1 code and map sensor code...relpaced driver side front o2 and map sensor....cleared codes after install .. also had code p1281 eng to cold to long .. put new dealer stat in .. is there a special bleeding sequence to go thru not reall... - 08' Chevy Avalanche check engine light on with decreased gas milage
More detailed information... DTC P1174 or P1175 Diagnostic Instructions - Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. - Review Strategy Based Diagnosis for an overview of the diagnostic approach. - Diagnostic Procedure Instructions provides an ... - 99 Jeep Grand Cherokee-overdrive issue
Guys I need some advice. I have had this 1999 Jeep Grand Cherokee a few years now and well its issues have issues. My main concern is the transmission not working in overdrive. I live in Georgia so it doesnt get cold here often but last winter when it did drop close to freezing I noticed it workign ...
آیاسنسور اکسیژن ntkدرپژو206برای ecuوالئو مشکل ایجاد می کند؟
