P0131 – Heated oxygen sensor (HO2S) / oxgen sensor (O2S) 1, bank 1 -low voltage
Last Updated 2016-07-05
P0131 | Heated oxygen sensor (HO2S) 1, bank 1 -low voltage (Buy Part On Amazon) | Exhaust leak, wiring short to earth, H025, ECM |
What Does Code P0131 Mean?
- DTC P0131 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1 (B1S1)
What are the common causes of code P0131 ?
Depending on year, make, and model, DTC P0131 may have number of causes. Here are some of the most common.
What are the symptoms of code P0131 ?
How do you troubleshoot code P0131 ?
Codes Related to P0131
