P0086 – Exhaust valve control solenoid, bank 2 -circuit high
Benjamin Jerew
Last Updated 2016-04-22
P0086 Exhaust valve control solenoid, bank 2 -circuit high
Wiring short to positive, exhaust valve control solenoid, ECM
  1. What Does Code P0086 Mean?
  2. What are the common causes of code P0086 ?
  3. What are the symptoms of code P0086 ?
  4. How do you troubleshoot code P0086 ?
  5. Codes Related to P0086
  6. Get Help with P0086
SS.1460388770
0-new-1-variocam_H-web
If the ECM detects a fault in the VVT solenoid valve circuit, such as voltage out of specification, it will set a diagnostic trouble code (DTC), P0086 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 2), and illuminate the check engine light (CEL).
Depending on year, make, and model, DTC P0086 may have number of causes. Here are some of the most common.
  • Circuit Problems – Wire harness and connector damage are the main causes of this VVT failure. Poor repair practices and rodent damage are common causes of this type of damage.
  • VVT Solenoid Valve Problems – The main failure here is an open circuit in the solenoid coil.
cvvt-continuous-variable-valve-timing-wiring-diagram
  • Connector and Harness Check – Check that the VVT solenoid valve connector is good, no bent or backed-out pins, corrosion, or water entry. Make sure the connector is firmly seated. Check the wire harness for damage, chafing, exposed or broken wires. Repair as necessary.
  • Voltage Check – With the engine running, you should have a minimum 13.4 V at the battery. Backprobe the VVT solenoid valve, usually located in the cylinder head or valve cover, and check for battery voltage.
    • If voltage is incorrect, suspect an open circuit between the ECM and the valve. Disconnect the connector and recheck for battery voltage. If incorrect, suspect an open circuit between the ECM and the valve. Inspect the wire harness and repair as necessary.
    • If voltage is correct, suspect a ground problem. With the key off and engine off, disconnect the VVT solenoid valve connector and the ECM connector. From the VVT solenoid valve connector, check both pins for short to each other and short to ground. You should measure infinite resistance to ground and across the pins. If incorrect, suspect a short circuit. Repair as necessary.
61l9DoyOdkL._SX425_
  • VVT Solenoid Valve Check
    • Check for resistance across the solenoid valve pins. You should measure between 5 Ω and 15 Ω, depending on manufacturer and temperature. Check your manual for the proper specification. If incorrect, replace the valve.
    • Check for resistance from the pins to ground. You should measure infinite resistance to ground. If incorrect, replace the valve.
  • P0076 Intake Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 1)
  • P0077 Intake Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 1)
  • P0078 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit (Bank 1)
  • P0079 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 1)
  • P0080 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 1)
  • P0081 Intake Variable Valve Timing (VVT) Control Solenoid Circuit (Bank 2)
  • P0082 Intake Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 2)
  • P0083 Intake Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 2)
  • P0084 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit (Bank 2)
  • P0085 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 2)
  • P0086 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 2)
