P0085 – Exhaust valve control solenoid, bank 2 -circuit low
Last Updated 2016-04-22
P0085 | Exhaust valve control solenoid, bank 2 -circuit low (Buy Part On Amazon) | Wiring short to earth, exhaust valve control solenoid, ECM |
What Does Code P0085 Mean?
If the ECM detects a fault in the VVT solenoid valve circuit, such as voltage out of specification, it will set a diagnostic trouble code (DTC), P0085 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 2), and illuminate the check engine light (CEL).
What are the common causes of code P0085 ?
Depending on year, make, and model, DTC P0085 may have number of causes. Here are some of the most common.
What are the symptoms of code P0085 ?
How do you troubleshoot code P0085 ?
- VVT Solenoid Valve Check
Codes Related to P0085
