P0084 – Exhaust valve control solenoid, bank 2 -circuit malfunction
| P0084 | Exhaust valve control solenoid, bank 2 -circuit malfunction (Buy Part On Amazon) | Wiring, exhaust valve control solenoid, ECM |
Where is the Valve timing control (VTC) oil control solenoid? See our guide to the Valve timing control (VTC) oil control solenoid – what it does, where it sits on the engine and how it fails.
- What Does Code P0084 Mean?
- What are the common causes of code P0084 ?
- What are the symptoms of code P0084 ?
- How do you troubleshoot code P0084 ?
- Codes Related to P0084
- Get Help with P0084
If the ECM detects a fault in the VVT solenoid valve circuit, such as voltage out of specification, it will set a diagnostic trouble code (DTC), P0084 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit (Bank 2), and illuminate the check engine light (CEL).
Depending on year, make, and model, DTC P0084 may have number of causes. Here are some of the most common.
- VVT Solenoid Valve Check
Reading P0084 on your car
A basic adapter will show you P0084, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
