P0083 – Intake valve control solenoid, bank 2 -circuit high
Last Updated 2016-04-22
P0083 | Intake valve control solenoid, bank 2 -circuit high (Buy Part On Amazon) | Wiring short to positive, intake valve control solenoid, ECM |
What Does Code P0083 Mean?
If the ECM detects a fault in the VVT solenoid valve circuit, such as voltage out of specification, it will set a diagnostic trouble code (DTC), P0083 Intake Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 2), and illuminate the check engine light (CEL).
What are the common causes of code P0083 ?
Depending on year, make, and model, DTC P0083 may have number of causes. Here are some of the most common.
What are the symptoms of code P0083 ?
How do you troubleshoot code P0083 ?
- VVT Solenoid Valve Check
Codes Related to P0083
