P0082 – Intake valve control solenoid, bank 2 -circuit low
Last Updated 2016-04-12
P0082 | Intake valve control solenoid, bank 2 -circuit low (Buy Part On Amazon) | Wiring short to earth, intake valve control solenoid, ECM |
What Does Code P0082 Mean?
If the ECM detects a fault in the VVT solenoid valve circuit, such as voltage out of specification, it will set a diagnostic trouble code (DTC), P0082 Intake Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 2), and illuminate the check engine light (CEL). Keep in mind that Bank 2 refers to the bank of cylinders opposite to cylinder #1 (V6, V8, and V10 engines).
What are the common causes of code P0082 ?
Depending on year, make, and model, DTC P0082 may have number of causes. Here are some of the most common.
What are the symptoms of code P0082 ?
How do you troubleshoot code P0082 ?
- VVT Solenoid Valve Check
Codes Related to P0082
i changed the solenoid and still have the code and rough ride. also miss fires on cylinders 1 and 2
