P0081 – Intake valve control solenoid, bank 2 -circuit malfunction
| P0081 | Intake valve control solenoid, bank 2 -circuit malfunction (Buy Part On Amazon) | Wiring, intake valve control solenoid, ECM |
Where is the Valve timing control (VTC) oil control solenoid? See our guide to the Valve timing control (VTC) oil control solenoid – what it does, where it sits on the engine and how it fails.
- What Does Code P0081 Mean?
- What are the common causes of code P0081 ?
- What are the symptoms of code P0081 ?
- How do you troubleshoot code P0081 ?
- Codes Related to P0081
- Get Help with P0081
If the ECM detects a fault in the VVT solenoid valve circuit, such as voltage out of specification, it will set a diagnostic trouble code (DTC), P0081 Intake Variable Valve Timing (VVT) Control Solenoid Circuit (Bank 2), and illuminate the check engine light (CEL). Keep in mind that Bank 2 refers to the bank of cylinders opposite to that containing cylinder #1 (V6, V8, and V10 engines).
Depending on year, make, and model, DTC P0081 may have number of causes. Here are some of the most common.
- VVT Solenoid Valve Check
- P0075 Intake Variable Valve Timing (VVT) Control Solenoid Circuit (Bank 1)
Reading P0081 on your car
A basic adapter will show you P0081, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
