P0077 – Intake valve control solenoid, bank 1 -circuit high
Last Updated 2016-04-12
P0077 | Intake valve control solenoid, bank 1 -circuit high (Buy Part On Amazon) | Wiring short to positive, intake valve control solenoid, ECM |
What Does Code P0077 Mean?
If the ECM detects a fault in the VVT solenoid valve circuit, such as voltage out of specification, it will set a diagnostic trouble code (DTC), P0077 Intake Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 1), and illuminate the check engine light (CEL). Keep in mind that Bank 1 refers to either an inline engine (most four- and five-cylinder engines, and some six-cylinder engines) or the bank of cylinders containing cylinder #1 (V6, V8, and V10 engines).
What are the common causes of code P0077 ?
Depending on year, make, and model, DTC P0077 may have number of causes. Here are some of the most common.
What are the symptoms of code P0077 ?
How do you troubleshoot code P0077 ?
- VVT Solenoid Valve Check
Codes Related to P0077
