P0076 – Intake valve control solenoid, bank 1 -circuit low
Last Updated 2016-04-12
P0076 Intake valve control solenoid, bank 1 -circuit low
Wiring short to earth, intake valve control solenoid, ECM
Where is the Valve timing control (VTC) oil control solenoid? See our guide to the Valve timing control (VTC) oil control solenoid – what it does, where it sits on the engine and how it fails.
  1. What Does Code P0076 Mean?
  2. What are the common causes of code P0076 ?
  3. What are the symptoms of code P0076 ?
  4. How do you troubleshoot code P0076 ?
  5. Codes Related to P0076
  6. Get Help with P0076
Illustration for trouble code P0075 - Intake valve control solenoid, bank 1 -circuit malfunction
If the ECM detects a fault in the VVT solenoid valve circuit, such as voltage out of specification, it will set a diagnostic trouble code (DTC), P0076 Intake Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 1), and illuminate the check engine light (CEL). Keep in mind that Bank 1 refers to either an inline engine (most four- and five-cylinder engines, and some six-cylinder engines) or the bank of cylinders containing cylinder #1 (V6, V8, and V10 engines).
Depending on year, make, and model, DTC P0076 may have number of causes. Here are some of the most common.
  • Circuit Problems – Wire harness and connector damage are the main causes of this VVT failure. Poor repair practices and rodent damage are common causes of this type of damage.
  • VVT Solenoid Valve Problems – The main failure here is an open circuit in the solenoid coil.
  • Connector and Harness Check – Check that the VVT solenoid valve connector is good, no bent or backed-out pins, corrosion, or water entry. Make sure the connector is firmly seated. Check the wire harness for damage, chafing, exposed or broken wires. Repair as necessary.
  • Voltage Check – With the engine running, you should have a minimum 13.4 V at the battery. Backprobe the VVT solenoid valve, usually located in the cylinder head or valve cover, and check for battery voltage.
    • If voltage is incorrect, suspect an open circuit between the ECM and the valve. Disconnect the connector and recheck for battery voltage. If incorrect, suspect an open circuit between the ECM and the valve. Inspect the wire harness and repair as necessary.
    • If voltage is correct, suspect a ground problem. With the key off and engine off, disconnect the VVT solenoid valve connector and the ECM connector. From the VVT solenoid valve connector, check both pins for short to each other and short to ground. You should measure infinite resistance to ground and across the pins. If incorrect, suspect a short circuit. Repair as necessary.
  • VVT Solenoid Valve Check
    • Check for resistance across the solenoid valve pins. You should measure between 5 Ω and 15 Ω, depending on manufacturer and temperature. Check your manual for the proper specification. If incorrect, replace the valve.
    • Check for resistance from the pins to ground. You should measure infinite resistance to ground. If incorrect, replace the valve.
  • P0076 Intake Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 1)
  • P0077 Intake Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 1)
  • P0078 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit (Bank 1)
  • P0079 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 1)
  • P0080 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 1)
  • P0081 Intake Variable Valve Timing (VVT) Control Solenoid Circuit (Bank 2)
  • P0082 Intake Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 2)
  • P0083 Intake Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 2)
  • P0084 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit (Bank 2)
  • P0085 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit Low (Bank 2)
  • P0086 Exhaust Variable Valve Timing (VVT) Control Solenoid Circuit High (Bank 2)
Reading P0076 on your car
A basic adapter will show you P0076, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
