P0075 – Intake valve control solenoid, bank 1 -circuit malfunction
P0075 | Intake valve control solenoid, bank 1 -circuit malfunction (Buy Part On Amazon) | Wiring, intake valve control solenoid, ECM |
- What Does Code P0075 Mean?
- What are the common causes of code P0075 ?
- What are the symptoms of code P0075 ?
- How do you troubleshoot code P0075 ?
- Codes Related to P0075
- Get Help with P0075
If the ECM detects a fault in the VVT solenoid valve circuit, such as voltage out of specification, it will set a diagnostic trouble code (DTC), P0075 Intake Variable Valve Timing (VVT) Control Solenoid Circuit (Bank 1), and illuminate the check engine light (CEL). Keep in mind that Bank 1 refers to either an inline engine (most four- and five-cylinder engines, and some six-cylinder engines) or the bank of cylinders containing cylinder #1 (V6, V8, and V10 engines).
Depending on year, make, and model, DTC P0075 may have number of causes. Here are some of the most common.
- VVT Solenoid Valve Check
Thank you for the knowledge you shared., I have Nissan x-trail 2004 year model. Then I scanned last Monday, then the code P1111 Intake Valve timing Valve cir/b1. So I replace the intake Valve Controller, but after replacing, the code came back again and again., do you know what the main problem like this? Thank you and advance
Is the Intake valve control solenoid for a 2002 Hyundai Santa Fe the same for a 2009 Hyundai Accent?
