P0068 – Manifold absolute pressure (MAP) sensor/mass air flow (MAF) sensor/throttle position correlation
Last Updated 2016-06-06
P0068 | Manifold absolute pressure (MAP) sensor/mass air flow (MAF) sensor/throttle position correlation (Buy Part On Amazon) | Wiring, MAP sensor, MAF sensor, mechanical fault |
What Does Code P0068 Mean?
P0068 means that the Powertrain Control Module (PCM) has detected an excessive degree of variation in the input voltage signal from the throttle position sensor (TPS) as compared with voltage input signals from the mass air flow (MAF) sensor and the manifold air pressure (MAP) sensor. The PCM reads and calculates these individual engine drivability sensor signals and then compares them to help develop fuel delivery and ignition timing strategy. The PCM also utilizes this information to ensure that the fuel-to-air ratio remains constant, controllable, and within acceptable limitations. If the detected voltage values of these three sensors (triangulated) fail to coincide with programmed desired parameters, over a specific period of time or engine revolutions, a diagnostic trouble code will be stored and a malfunction indicator lamp will likely be illuminated.
What are the common causes of code P0068 ?
The most frequent contributors to this code being set are large vacuum leaks as a result of cracked, broken, or otherwise collapsed vacuum lines and hoses. Other sources of vacuum leaks include defective intake and throttle body gaskets, EGR valve and gasket malfunctions, and vacuum operated component (brake boosters, etc.) defects. Other possible causes could include a cracked or disconnected air intake pipe, clogged air filter, a faulty TPS, MAF, and/or MAP sensor, or a defective PCM.
What are the symptoms of code P0068 ?
The symptoms which could accompany this code include a reduction in fuel efficiency, decreased engine performance, and significant hesitation upon acceleration. Of course the service engine soon lamp will likely be illuminated.
How do you troubleshoot code P0068 ?
A scanner, digital volt/ohmmeter (DVOM), and a manufacturer’s service manual will be helpful.
Use the scanner to retrieve and record all trouble codes. Clear the codes and test drive the vehicle (if possible). After the initial test drive, reconnect the scanner and see if the code/s has returned. Codes that do not return are usually referred to as intermittent codes. Theses codes can often be more difficult to diagnose.
Begin every diagnosis with a visual inspection of the related components, connectors, and circuitry. Components that appear to be corroded, damaged, or disconnected should be repaired before continuing with your diagnosis. Make sure that the vehicle battery is fully charged and that the battery cable connections are corrosion free and secure. Low battery voltage will skew your live test data and make a correct diagnosis nearly impossible.
MAP Sensor Testing
The MAP sensor (sometimes called the Barometric Pressure Sensor) is used by the PCM to detect the degree of vacuum pressure inside the intake manifold when the engine is running. The position of the TPS, RPM level of the engine, and input voltage signal of the MAF sensor are used in conjunction with the MAP sensor input signal to calculate engine drivability strategy. This sensor typically threads or is inserted directly into the intake manifold and is sealed to prevent vacuum leaks. The MAP sensor uses varying resistance to change the input signal voltage reading to the PCM. Use a DVOM to measure live data at the sensor connector. Obtain sensor and circuit resistance data from the service manual. Test sensor resistance and replace defective sensors as necessary.
MAF Sensor Testing
The MAF sensor is normally a vane type sensor with an exposed heated element. Battery voltage is used to maintain a high temperature across the element. As air flow increases, across the heated element, the temperature drops. This drop in temperature is recognized by the PCM as an increase in air flow to the intake manifold. The PCM uses this input data to develop fuel delivery strategy. Since the MAF reflects varying degrees of intake air, you may use the DVOM to test live data voltage readings at the MAF connector while operating the throttle manually. Measure sensor resistance values and compare them with the manufacturer’s specifications. Replace the sensor or repair open circuits and connectors as required.
TPS Testing
Modern TPS switches are of the non-contact variety. They may include hall-effect sensors, magnetoresistive type sensors, and inductive sensors. Typically the TPS is supplied with a 5-volt reference signal (from the PCM), and a battery ground. A signal circuit allows the TPS to input a voltage signal from the TPS to the PCM. The TPS is designed to provide a means for varying the voltage input signal to the PCM. As the throttle plate is opened The PCM typically receives a voltage signal that ranges between .5 and 5.0-volts. When the throttle plate is closed (at idle) the TPS is at its highest level of resistance. This maximum level of resistance means that the input voltage signal to the PCM is at its lowest possible level (usually .5-volts). At wide-open-throttle (WOT) the TPS provides its minimum level of resistance to the input signal circuit. At minimum resistance, the input voltage signal circuit will be at its highest point (usually 5.0-volts). The varying input voltage level is controlled in the same manner throughout the throttle curve and monitored by the PCM. The TPS can be tested using a DVOM and the manufacturer’s wiring diagram. Test for a reference voltage signal and a ground signal. If these signals coincide with the manufacturer’s specifications, test the input voltage signal to the PCM while operating the throttle manually. Observe live voltage data and pay particular attention to glitches and other consistencies. Refer to the manufacturer’s service manual (or equivalent) for application-specific voltage and resistance values.
If all of the related sensor values comply with the manufacturer’s specifications, you may continue with your diagnosis by disconnecting the electrical connectors from the sensor/s in question and all related control modules. Failure to disconnect control modules could result in module damage when using the DVOM on the resistance setting. Utilize the wiring diagrams and connector views (found in the service manual) to perform system continuity and resistance tests on all related circuits. Circuits that prove to be open or shorted will need to be repaired or replaced according to vehicle manufacturer guidelines.
After repairs are finished, use the scanner to clear all the codes and then test drive the vehicle to make sure that the repair was successful.
Codes Related to P0068
When this code is exhibited these additional codes may accompany it:
- P0100 Mass or Volume Air Flow Circuit Malfunction
- P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
- P0102 Mass or Volume Air Flow Circuit Low Input
- P0103 Mass or Volume Air Flow Circuit High Input
- P0104 Mass or Volume Air Flow Circuit Intermittent
- P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
- P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
- P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
- P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
- P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
- P0120 Throttle Position Sensor/Switch A Circuit Malfunction
- P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
- P0122 Throttle Position Sensor/Switch A Circuit Low Input
- P0123 Throttle Position Sensor/Switch A Circuit High Input
- P0124 Throttle Position Sensor/Switch A Circuit Intermittent
[…] is something that I found on the net that may explain things a little better than my attempt above: P0068 ? Manifold absolute pressure (MAP) sensor/mass air flow (MAF) sensor/throttle position correla… Click HERE for Service Manuals My Build Thread atroph is online now […]
I’m having a problem with my car after my snout rebuild & I’m hoping that maybe you can help. I have a 2005 Chevy Cobalt SS/SC that has a factory Eaton M62 supercharger. My car & SC has just reached 175k miles & I was starting to get some noise coming from both my snout & case needle bearings. Rather than dropping over $1200 for a new factory SC I just went ahead & picked up a rebuild kit that consisted of the two snout bearings a new snout seal needle bearing grease a new SC coupler & SC oil. I didn’t want to take the chance on doing this myself so I went ahead & paid my trained technician who does all of my mods to do the rebuild for me. Now granted my tech has never done a rebuild like this before however he has had my SC off & apart before when we pressed on a smaller pulley plus we both did our research & used a utube video to help with the rebuild.
My tech did everything the correct way he used his press to press out the old snout bearings & press on the new ones. We didn’t replace the needle bearings we just left them seated in the case & reached in & greased them with the needle bearing grease that came with the kit.
My tech did have a problem with the inner snout bearing coming un seated when he was pressing on the 2nd snout bearing however he took it back apart & managed to re seat the inner bearing.
After the rebuild was complete before he attached my snout back to the SC he turned my pulley by hand & it was stiff & not easy to turn. The instructions that we used did say that it’s normal for it to be stiff at first due to the new seal breaking in so we left it alone.
My tech installed my SC back on he hooked back up all of the vacuum hoses & made sure all of the sensors were hooked back up properly.
Here’s where the problems began. My car has never had an issue however the 2nd I started my car after the rebuild my belt started to squeal which my belt has never squealed my check engine light came on & my idle started to go crazy going up & down. We turned my car off & checked the trouble codes. The four trouble codes that we got are
P0069
P0121
P1101
P0068
We went ahead & cleared the codes & then took my car for a spin. The belt squeal only happens when the car is first started however after driving for about a minute it slowly goes away. We didn’t get out of 2nd gear before my car went into reduced engine power the check engine light came back on & the same 4 codes came back.
This all happened this time last week so yes my tech has had my car for over a week now & can’t figure out what’s wrong. He seems to think that these trouble codes are related to a 5 volt reference which he thinks is being caused by a bad wire that we may have damaged when taking off or putting back on the SC. He has cleaned my throttle body & checked all of the sensors to make sure they are plugged back in right he also checked all of my vacuum hoses for leaks & hasn’t found any.
He did find one bad wire that was either next to or going into my throttle body so he thought he had found the problem. He repaired the faulty wire cleared the codes & took it for a spin & everything was fine however a couple hours later he took it back out again & it went right back into reduced engine power with the check engine light & same four codes.
At this time he still thinks that we have a wiring issue so he said that he’s going to continue to chase the wires until he finds the bad one. He said if he has to he will remove my entire harness to find it.
I could really use your expert opinion on this. My thinking is that this issue had to have been caused by the SC rebuild I mean after all my car was perfect before I took it to him & one of the only things that we did while it was in his care was the SC snout rebuild.
Like I had mentioned before my belt has never squealed until now so my belt squealing tells me that it’s slipping now why would my belt be slipping after the rebuild? Like I also mentioned he had a hard time turning the pulley after the rebuild it was really stiff so could the belt be slipping because it to is having trouble turning the pulley which in return would effect the amount of air flow & pressure & most of these trouble codes have to do with airflow.
Do you agree with me that this issue could be a result of the SC rebuild? & if so what advice can you give me ? What should I have my tech look at ? Any advice that you could give me would be so helpful I’m lost at this point
Hi,
The supercharger is designed to pump more air into the engine than it would normally use. This excess air creates a boost pressure in the intake manifold. On your vehicle, maximum boost is 12 PSI. When boost is not desired, such as during idle and light throttle cruising, the excess air is routed through a bypass passage between the intake manifold and super charger inlet.This action is controlled by a bypass valve which is connected to a vacuum source.
The codes you listed, and the fact that the issues didn’t occur before the supercharger was tampered with, lead me to believe something went wrong during the repair process. Codes P0068 and P0069 indicate a discrepancy between the amount of air entering the engine and the sensors input to the PCM. Code P1101 stands for “Intake Air Flow System Performance Problem.”
Without inspecting the vehicle firsthand, I’m not exactly sure which part of the supercharger repair got botched, but I doubt it’s a problem with the wiring. I’d bet on it being a mechanical problem with the supercharger itself, or the way it was installed. The technician who worked on your vehicle should correct this and do right by you.
