P0062 – Heated oxygen sensor (HO2S) 3, bank 2, heater control circuit malfunction
Last Updated 2016-04-12
P0062 | Heated oxygen sensor (HO2S) 3, bank 2, heater control circuit malfunction (Buy Part On Amazon) | Wiring, HO2S, ECM |
What Does Code P0062 Mean?
Code P0062 stands for HO2S heater Performance Bank 2 Sensor 3. This indicates the PCM has detected a problem with heater circuit of the downstream oxygen sensor. Bank 2 refers to the side of the engine opposite the #1 cylinder. The related code is P0042 HO2S Heater Performance Bank 1 Sensor 3. This indicates the PCM has detected a problem with the bank 1 downstream oxygen sensor heater.
Oxygen sensor diagram
(Courtesy: samarins.com)
What are the common causes of code P0062 ?
To sum things up, the common causes for code P0062 are as follows:
What are the symptoms of code P0062 ?
How do you troubleshoot code P0062 ?
(Courtesy: alldata.com)
(Courtesy: 2carpros.com)
Codes Related to P0062
- DTC P0030: HO2S Heater Control Circuit Bank 1 Sensor 1
- DTC P0036: HO2S Heater Control Circuit Bank 1 Sensor 2
- DTC P0053: HO2S Heater Resistance Circuit Bank 1 Sensor 1
- DTC P0054: HO2S Heater Resistance Circuit Bank 1 Sensor 2
- DTC P0135: HO2S Heater Performance Bank 1 Sensor 1
- DTC P0141: HO2S Heater Performance Bank 1 Sensor 2
- DTC P0050: HO2S Heater Control Bank 2 Sensor 1
- DTC P0056: HO2S Heater Control Bank 2 Sensor 2
- DTC P0059: HO2S Heater Resistance Bank 2 Sensor 1
- DTC P0060: HO2S Heater Resistance Bank 2 Sensor 2
- DTC P0155: HO2S Heater Performance Bank 2 Sensor 1
- DTC P0167: HO2S Heater Performance Bank 2 Sensor 3
