P0050 – Heated oxygen sensor (HO2S) 1, bank 2, heater control circuit malfunction
Last Updated 2016-04-12
P0050 | Heated oxygen sensor (HO2S) 1, bank 2, heater control circuit malfunction | Wiring, HO2S, ECM |
What Does Code P0050 Mean?
The upstream oxygen sensor (O2S) is located ahead of the catalytic converter. It is used to determine the concentration of oxygen in the exhaust gas. This information is used by the PCM to control the engine air/fuel mixture. The sensor compares amount of oxygen in the exhaust to the surrounding air (there is an opening in the sensor that is exposed to the atmosphere). It generates a corresponding voltage which is transmitted to the PCM. The PCM then controls injector pulse based on this value.
Modern vehicles use a heated oxygen sensor (HO2S). These sensors contain a heating element that brings the sensor to operating temperature faster. This allows the PCM to use the signals input sooner, for more precise fuel control and reduced emissions. The heater circuit is energized through a relay that closes when the engine is cranked. The PCM monitors the heater circuit and will turn on the check engine light if it finds a problem.
Code P0050 stands for Oxygen O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 1). This indicates the PCM has detected a problem with the bank 2 oxygen sensor. Bank 2 refers to the side of the engine opposite the #1 cylinder.
A typical heated oxygen sensor
(Courtesy: easterncatalytic.com)
What are the common causes of code P0050?
To sum things up, the common causes for code P0050 are as follows:
What are the symptoms of code P0050?
In theory, a failed O2 heater will result in poor fuel economy. But you’ll probably never notice the difference during operation. The only thing you will notice is an illuminated check engine light on your dashboard. If your registration is due, you will also fail the emissions test.
How do you troubleshoot code P0050?
(Courtesy: alldata.com)
(Courtesy: 2carpros.com)
Codes Related to P0050
Code P0050 is the most closely related code to P0030. It stands for 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1). So, it is essentially the same code, but for the opposite bank of the engine. All of the same diagnostic steps apply.
BAT Team Discussions for P0050
- 08' Chevy Avalanche check engine light on with decreased gas milage
More detailed information... DTC P1174 or P1175 Diagnostic Instructions - Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. - Review Strategy Based Diagnosis for an overview of the diagnostic approach. - Diagnostic Procedure Instructions provides an ...
[…] http://www.troublecodes.net/pcodes/p0050/ You might check the relay and fuses for the o2 heater circuit. […]
