P0044 – Heated oxygen sensor (HO2S) 3, bank 1, heater control -circuit high
Last Updated 2016-06-11
P0044 | Heated oxygen sensor (HO2S) 3, bank 1, heater control -circuit high (Buy Part On Amazon) | Wiring short to positive, HO2S, ECM |
What Does Code P0044 Mean?
OBD II fault code P0044 is defined as “Oxygen Sensor Heater Control Circuit High (Bank 1 Sensor 3), and is set when the PCM (Powertrain Control Module) detects a signal voltage from oxygen sensor #3 that does not fall within the predefined range for that sensor. Note that “Bank 1” refers to the bank of cylinders that contains cylinder #1, and that “Sensor 3” refers to the 2nd oxygen sensor that is located after (downstream of) the catalytic converter(s).
Note: Some V8 and V10 engines have two sensors upstream (per bank of cylinders) of the catalytic converter to more accurately monitor emissions. On these engines, the sensor located after the converter would be sensor #3, and everything that applies to sensor #2 on other engines would apply to sensor #3. There is no difference between sensor #2 and #3 except that they are numbered differently to allow for an additional sensor upstream of the converter on each cylinder bank.
On most applications, the electrical resistance of an oxygen sensor will be 8 Ohms (or very close to it), and deviations of 10% of this value will set code P0044 and trigger the CHECK ENGINE light. Input voltages in all oxygen sensor heater control circuits should be equal to battery voltage; deviations of 10% will also set code P0044 and trigger the CHECK ENGINE light. Note that the electrical resistance may differ on some applications- consult the manual on the exact values for the application being worked on.
During normal (closed loop) engine operation, the signal voltage from the #3 oxygen sensor(s) will vary constantly, and in cases where the PCM detects no changes in the sensor signal voltage(s) for a period of about 8 continuous seconds, code P0044 can be set and the CHECK ENGINE light triggered.
Oxygen sensors #2 and #3 monitor the functioning of the catalytic converter, whereas sensor #1 monitors fuel/air metering. In practical terms, this means that sensor #1 measures the amount of oxygen in the exhaust stream (as a function of the combustion process) before it enters the catalytic converter, while sensors #2 and #3 measure how well the converter(s) copes with cleaning up the exhaust stream.
What are the common causes of code P0044 ?
Common causes of code P0044 include the following-
- Burnt wiring caused by wiring that runs too close to hot exhaust components
- Short circuits caused by burnt wiring
- Bad connections caused by corrosion, or impact damage caused by road debris
- Bad ground connections
- Blown fuses (where applicable) on the heater control circuit
Note that vacuum leaks that cause unmetered air to enter the engine are more likely to cause Oxygen Sensor Range/Performance issues than high input voltages in the control circuit.
What are the symptoms of code P0044 ?
While the symptoms of code P0044 are much the same on all vehicles, the severity of one or more symptoms may differ from vehicle to vehicle. Typical symptoms include the following-
- Rich-running condition
- Lean-running condition
- Increased fuel consumption
- Loss of power
- Rough idling
- Visible black smoke from the tail pipe
- Hard starting in some cases
- Illuminated CHECK ENGINE light
- Stored trouble code(s)
How do you troubleshoot code P0044 ?
NOTE #1: It should be noted that code P0044 indicates a fault in the oxygen sensors’ heating control circuits, rather than issues with fuel/air metering. In cases where codes relating to fuel/air metering are present along with P0044, these codes must be resolved before starting an electrical diagnosis of code P0044.
NOTE #2: At the risk of overstating the case, code P0044 relates to oxygen sensors that are located after the catalytic converter. To avoid confusion, and prevent testing/replacement of the wrong oxygen sensors, always consult the repair manual to determine the location, color-coding, and routing of the wiring associated with #3 oxygen sensors.
NOTE #3: Check for, and repair all exhaust leaks before starting an electrical diagnosis of code P0044. Exhaust leaks can contaminate the atmospheric air used by oxygen sensors, which contamination can result in inaccurate readings.
Codes Related to P0044
P0043 – Relates to “Oxygen Sensor Heater Control Circuit Low (Bank 1 Sensor 3)”
