P0043 – Heated oxygen sensor (HO2S) 3, bank 1, heater control circuit low
Reinier
Last Updated 2016-06-11
P0043 Heated oxygen sensor (HO2S) 3, bank 1, heater control circuit low
Wiring short to earth, 1"1025, ECM
  1. What Does Code P0043 Mean?
  2. What are the common causes of code P0043 ?
  3. What are the symptoms of code P0043 ?
  4. How do you troubleshoot code P0043 ?
  5. Codes Related to P0043
  6. Get Help with P0043
OBD II fault code P0043 is defined as “Oxygen Sensor Heater Control Circuit Low (Bank 1 Sensor 3), and is set when the PCM (Powertrain Control Module) detects a signal voltage from oxygen sensor #3 that does not fall within the predefined range for that sensor. Note that “Bank 1” refers to the bank of cylinders that contains cylinder #1, and that “Sensor 3” refers to the 2nd oxygen sensor that is located after (downstream of) the catalytic converter(s).
Note: Some V8 and V10 engines have two sensors upstream (per bank of cylinders) of the catalytic converter to more accurately monitor emissions. On these engines, the sensor located after the converter would be sensor #3, and everything that applies to sensor #2 on other engines would apply to sensor #3.   There is no difference between sensor #2 and #3 except that they are numbered differently to allow for an additional sensor upstream of the converter on each cylinder bank.
On most applications, the electrical resistance of an oxygen sensor will be 8 Ohms (or very close to it), and deviations of 10% of this value will set code P0043 and trigger the CHECK ENGINE light. Input voltages in all oxygen sensor heater control circuits should be equal to battery voltage; deviations of 10% will also set code P0043 and trigger the CHECK ENGINE light. Note that the electrical resistance may differ on some applications- consult the manual on the exact values for the application being worked on.
During normal (closed loop) engine operation, the signal voltage from the #3 oxygen sensor(s) will vary constantly, and in cases where the PCM detects no changes in the sensor signal voltage(s) for a period of about 8 continuous seconds, code P0043 can be set and the CHECK ENGINE light triggered.
Oxygen sensors #2 and #3 monitor the functioning of the catalytic converter, whereas sensor #1 monitors fuel/air metering. In practical terms, this means that sensor #1 measures the amount of oxygen in the exhaust stream (as a function of the combustion process) before it enters the catalytic converter, while sensors #2 and #3 measures how well the converter(s) copes with cleaning up the exhaust stream.
oxygen-fuel-sensors
Note: Circuit Low Input codes are often the result of low battery voltages (that can have many possible causes), bad connections across electrical connectors or previously repaired wiring, as well as corrosion in electrical connectors. Other possible causes of low input voltages include poor installation of aftermarket components, poor quality aftermarket components like fuses, relays, and switches, and modification of the electrical system that could include the use of conductors that are not rated for use in a particular application. However, poor connections often result in high resistances in some parts of the circuit, which is why it is important to perform resistance and continuity checks during the diagnostic procedure.
Common causes of code P0043 include the following-
  • Burnt wiring caused by wiring that runs too close to hot exhaust components
  • Short circuits caused by burnt wiring
  • Bad connections caused by corrosion, or impact damage caused by road debris
  • Bad ground connections
  • Low battery voltage
  • Blown fuses (where applicable) on the heater control circuit
Note that vacuum leaks that cause unmetered air to enter the engine are more likely to cause Oxygen Sensor Range/Performance issues than low input voltages in the control circuit.
While the symptoms of code P0043 are much the same on all vehicles, the severity of one or more symptoms may differ from vehicle to vehicle. Typical symptoms include the following-
  • Rich-running condition
  • Lean-running condition
  • Increased fuel consumption
  • Loss of power
  • Rough idling
  • Visible black smoke from the tail pipe
  • Hard starting in some cases
  • Illuminated CHECK ENGINE light
  • Stored trouble code(s)
NOTE #1: It should be noted that code P0043 indicates a fault in the oxygen sensors’ heating control circuits, rather than issues with fuel/air metering. In cases where codes relating to fuel/air metering are present along with P0043, these codes must be resolved before starting an electrical diagnosis of code P0043.
NOTE #2: At the risk of overstating the case, code P0043 relates to oxygen sensors that are located after the catalytic converter. To avoid confusion, and prevent testing/replacement of the wrong oxygen sensors, always consult the repair manual to determine the location, color-coding, and routing of the wiring associated with #3 oxygen sensors.
NOTE #3: Check for, and repair all exhaust leaks before starting an electrical diagnosis of code P0043. Exhaust leaks can contaminate the atmospheric air used by oxygen sensors, which contamination can result in inaccurate readings.
P0044 – Relates to Oxygen Sensor Heater Control Circuit High (Bank 1 Sensor 3)”
