P0038 – Heated oxygen sensor (HO2S) 2, bank 1, heater control -circuit high
Last Updated 2016-06-10
P0038 | Heated oxygen sensor (HO2S) 2, bank 1, heater control -circuit high | Wiring short to positive, HO2S, ECM |
What Does Code P0038 Mean?
OBD II fault code P0038 is defined as “Oxygen Sensor Heater Control Circuit High (Bank 1 Sensor 2), and is set when the PCM (Powertrain Control Module) detects a signal voltage from oxygen sensor #2 that does not fall within the predefined range for that sensor. Note that “Bank 1” refers to the bank of cylinders that contains cylinder #1, and that “Sensor 2” refers to the oxygen sensor that is located after (downstream of) the catalytic converter(s).
On most applications, the electrical resistance of an oxygen sensor will be 8 Ohms (or very close to it), and deviations of 10% of this value will set code P0038 and trigger the CHECK ENGINE light. Input voltages in all oxygen sensor heater control circuits should be equal to battery voltage; deviations of 10% will also set code P0038 and trigger the CHECK ENGINE light. Note that the electrical resistance may differ on some applications- consult the manual on the exact values for the application being worked on.
During normal (closed loop) engine operation, the signal voltage from the #2 oxygen sensor(s) will vary constantly, and in cases where the PCM detects no changes in the sensor signal voltage(s) for a period of about 8 continuous seconds, code P0038 can be set and the CHECK ENGINE light triggered.
Oxygen sensor #2 monitors the functioning of the catalytic converter, whereas sensor #1 monitors fuel/air metering. In practical terms, this means that sensor #1 measures the amount of oxygen in the exhaust stream (as a function of the combustion process) before it enters the catalytic converter, while sensor #2 measures how well the converter(s) copes with cleaning up the exhaust stream.
What are the common causes of code P0038 ?
Common causes of code P0038 include the following-
- Burnt wiring caused by wiring that runs too close to hot exhaust components
- Short circuits caused by burnt wiring
- Bad connections caused by corrosion, or impact damage caused by road debris
- Bad ground connections
- Blown fuses (where applicable) on the heater control circuit
Note that vacuum leaks that cause unmetered air to enter the engine are more likely to cause Oxygen Sensor Range/Performance issues than high input voltages in the control circuit.
What are the symptoms of code P0038 ?
While the symptoms of code P0038 are much the same on all vehicles, the severity of one or more symptoms may differ from vehicle to vehicle. Typical symptoms include the following-
- Rich-running condition
- Lean-running condition
- Increased fuel consumption
- Loss of power
- Rough idling
- Visible black smoke from the tail pipe
- Hard starting in some cases
- Illuminated CHECK ENGINE light
- Stored trouble code(s)
How do you troubleshoot code P0038 ?
NOTE #1: It should be noted that code P0038 indicates a fault in the oxygen sensors’ heating control circuits, rather than issues with fuel/air metering. In cases where codes relating to fuel/air metering are present along with P0038, these codes must be resolved before starting an electrical diagnosis of code P0038.
NOTE #2: At the risk of overstating the case, code P0038 relates to oxygen sensors that are located after the catalytic converter. To avoid confusion, and prevent testing/replacement of the wrong oxygen sensors, always consult the repair manual to determine the location, color-coding, and routing of the wiring associated with #2 oxygen sensors.
NOTE #3: Check for, and repair all exhaust leaks before starting an electrical diagnosis of code P0038. Exhaust leaks can contaminate the atmospheric air used by oxygen sensors, which contamination can result in inaccurate readings.
Codes Related to P0038
P0037 – Relates to “Oxygen Sensor Heater Control Circuit Low (Bank 1 Sensor 2)”
BAT Team Discussions for P0038
- PT cruiser P0038 fault
Hi The wifes PT Cruiser2004 Non turbo automatic has a P0038 fault Should I replace the sensor ? or is it something else and if I'm not mistaken this is the one after the Cat ? Thanks for your help, Ed... - 03 PT Cruiser Turbo CEL Issues
Spent Saturday afternoon stripping all the tape from the harness junctions everywhere I could reach. Slid the mesh covering back to check the actual harness splice points and to look for damaged wires. I found no issues with the harness. I also pulled all the connectors and checked for corrosion but... - 2007 Nisssan Versa
friend has a 2007 nissan versa 1.8L auto getting trouble codes P0038 and P1148 the first is saying H02S heater control circuit high bank 1 sensor 2 and the P1148 is nissan specific showing closed loop control bank 1 i don't have alot of tech goodies to do better figure just generic scan tool and a b... - Intermittent O2 sensor code
You state you suspect it was the downstream sensor which in my language means B1S2 sensor. Check for heater circuit in conjunction with codes P0037, P0038 and P0141. P0136-139 are for oxygen sensor circuit malfunction, B1S2. Provided are flow charts for those codes if they are to appear. Although...
Thank u so much for this amazing piece of details
Excellent info. Saved me a trip to the mechanic
