P0036 – Heated oxygen sensor (HO2S) 2, bank 1, heater control -circuit malfunction
Last Updated 2016-04-12
P0036 | Heated oxygen sensor (HO2S) 2, bank 1, heater control -circuit malfunction (Buy Part On Amazon) | Wiring, HO2S, ECM |
What Does Code P0036 Mean?
Code P0036 stands for HO2S heater Performance Bank 1 Sensor 2. This indicates the PCM has detected a problem with heater circuit of the downstream oxygen sensor. Bank 1 refers to the side of the engine that has the #1 cylinder. Bank 2 is the opposite side of the engine. If you’ve got a four-cylinder, there will only be one bank. The related code for the other bank is P0056 HO2S Heater Performance Bank 2 Sensor 2. This indicates the PCM has detected a problem with the bank 2 downstream oxygen sensor heater.
Oxygen sensor diagram
(Courtesy: samarins.com)
What are the common causes of code P0036 ?
To sum things up, the common causes for code P0036 are as follows:
What are the symptoms of code P0036 ?
How do you troubleshoot code P0036 ?
(Courtesy: alldata.com)
(Courtesy: 2carpros.com)
Codes Related to P0036
- DTC P0030: HO2S Heater Control Circuit Bank 1 Sensor 1
- DTC P0036: HO2S Heater Control Circuit Bank 1 Sensor 2
- DTC P0053: HO2S Heater Resistance Circuit Bank 1 Sensor 1
- DTC P0054: HO2S Heater Resistance Circuit Bank 1 Sensor 2
- DTC P0135: HO2S Heater Performance Bank 1 Sensor 1
- DTC P0141: HO2S Heater Performance Bank 1 Sensor 2
- DTC P0050: HO2S Heater Control Bank 2 Sensor 1
- DTC P0056: HO2S Heater Control Bank 2 Sensor 2
- DTC P0059: HO2S Heater Resistance Bank 2 Sensor 1
- DTC P0060: HO2S Heater Resistance Bank 2 Sensor 2
- DTC P0155: HO2S Heater Performance Bank 2 Sensor 1
- DTC P0161: HO2S Heater Performance Bank 2 Sensor 2
were is p0036 heater sensor
Will this sensor cause my truck to go into limp mode
Hi Demetrius,
This code alone should not cause your vehicle to go into limp mode. This code simply means that the heater circuit for the downstream O2 sensor is not functioning properly. Since this sensor is used as a catalyst monitor, and not for fuel control, there is no reason for the vehicle to go into limp mode. My guess is that if your vehicle is going into limp mode, you have other codes stored in addition to P0036.
