P0030 – Heated oxygen sensor (HO2S) 1, bank 1, heater control -circuit malfunction
Last Updated 2016-06-02
P0030 | Heated oxygen sensor (HO2S) 1, bank 1, heater control -circuit malfunction | Wiring, HO2S, ECM |
What Does Code P0030 Mean?
The upstream oxygen sensor (O2S) is located ahead of the catalytic converter. It is used to determine the concentration of oxygen in the exhaust gas. This information is used by the PCM to control the engine air/fuel mixture. The sensor compares amount of oxygen in the exhaust to the surrounding air (there is an opening in the sensor that is exposed to the atmosphere). It generates a corresponding voltage which is transmitted to the PCM. The PCM then controls injector pulse based on this value.
Modern vehicles use a heated oxygen sensor (HO2S). These sensors contain a heating element that brings the sensor to operating temperature faster. This allows the PCM to use the signals input sooner, for more precise fuel control and reduced emissions. The heater circuit is energized through a relay that closes when the engine is cranked. The PCM monitors the heater circuit and will turn on the check engine light if it finds a problem.
Code P0030 stands for Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1). This indicates the PCM has detected a problem with the bank 1 oxygen sensor. Bank 1 refers to the side of the engine that has the #1 cylinder. Bank 2 is the opposite side of the engine. If you’ve got a four-cylinder, there will only be one bank.
A typical heated oxygen sensor
(Courtesy: easterncatalytic.com)
What are the common causes of code P0030 ?
To sum things up, the common causes for code P0030 are as follows:
What are the symptoms of code P0030 ?
In theory, a failed O2 heater will result in poor fuel economy. But you’ll probably never notice the difference during operation. The only thing you will notice is an illuminated check engine light on your dashboard. If your registration is due, you will also fail the emissions test.
How do you troubleshoot code P0030 ?
(Courtesy: alldata.com)
(Courtesy: 2carpros.com)
Codes Related to P0030
Code P0050 is the most closely related code to P0030. It stands for 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1). So, it is essentially the same code, but for the opposite bank of the engine. All of the same diagnostic steps apply.
BAT Team Discussions for P0030
- Colorado 2006 OBD2 code P0030, poor idle above 197 DEG
I have a 2006 Colorado that idles rough when in traffic and temp moves up a few degress. Hooked up the scanner and code shows P0030. Changed O2 sensor and still have problem and code. Checked fuse to sensor and is ok. Only misses at idle when temp gets about 199 deg on Actron scanner. Never skips be... - 08' Chevy Avalanche check engine light on with decreased gas milage
More detailed information... DTC P1174 or P1175 Diagnostic Instructions - Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. - Review Strategy Based Diagnosis for an overview of the diagnostic approach. - Diagnostic Procedure Instructions provides an ...
Great information clearly explained thank you so much.
Nick-
Thanks for the encouraging words. We hope that this information helps our readers fix their cars easier. If you had a good experience on our site, please be sure to let others know about it!
wow this information is what the doctor ordered i really thank you from my heart.
got more info here than chiltons
I would definitely test the sensor itself, first. I just recently bought a sensor that was dead out of the box. The car almost immediately threw a P0030 code after installing it. I tested the heater wires on the sensor, and it failed the continuity test.
Just to double check, I tested the old sensor I had just removed, and it passed. I reinstalled the old sensor and ran it for a while – the engine check light never came back on. The old sensor still needs to be replaced, as it has over 200K miles on it and has become a touch “lazy.” The heater circuit is obviously still good, though.
I guess even reputable companies like Denso can produce a few duds.
p2237-powertrain 2)02 sensor positive current control circuit open bank1 sensor1 problem.
how to solve this issue i am change my 02 sensor but problem is running
Great info, keep getting this fault, but car running fine, but. Its was a 1.4 fiesta mk6, but it’s running a 1.6s engine, but on the 1.4 ecu as ecu clocks, alarm are all tied together, l have the 1.6s ecu and dash, which thinking of putting in 🙂
