P0018 – Crankshaft position/camshaft position, bank 2 sensor A -correlation
Avatar photo
By Mia (Contact Me)
Last Updated 2015-12-21
P0018 Crankshaft position/camshaft position, bank 2 sensor A -correlation
Wiring, CKP sensor, CMP sensor, mechanical fault
  1. What Does Code P0018 Mean?
  2. What are the common causes of code P0018 ?
  3. What are the symptoms of code P0018 ?
  4. How do you troubleshoot code P0018 ?
  5. Codes Related to P0018
  6. Get Help with P0018
The camshaft position sensor (CMP) is used to determine the position of the camshaft(s). It relays this information to the powertrain control module (PCM). The PCM then uses this information to control the fuel injectors, and on some applications, for ignition timing. The crankshaft position sensor (CKP) relays crankshaft position and engine RPM to the PCM, or ignition module. This information is used but the PCM to control ignition timing, and in some applications, it is also used to control fuel injection.
The two common CMP and CKP designs are Hall Effect and permanent magnet.
  • Permanent magnet: creates an AC voltage signal that is proportional to engine speed.
Diagram of a magnetic position sensor over a reluctor wheel, labelling the permanent magnet, soft iron pole pin, solenoid windings and the air gap above the passing teeth
A permanent magnet crankshaft sensor
(Courtesy: CP Fitters)
  • Hall Effect: uses a reference voltage from the PCM to produce a DC voltage signal.
Circuit diagram of a Hall effect position sensor with its 5 volt supply and square-wave output, noting that the ECM triggers on the rising edge as a tooth moves away from the sensor
A Hall Effect crankshaft sensor
(Courtesy: nwmobilemechanicdotcom)
Inside the engine, the crankshaft and camshaft are held together by a timing belt or timing chain, which keeps them synchronized. The CKP and CMP sensors work together to keep the PCM informed about engine timing. Should the timing be off, the PCM will set a code P0018. This code stands for Crankshaft Position – Camshaft Position Correlation (Bank 2 Sensor A).
To sum things up, the common causes for code P0018 are as follows:
  • A faulty cam or crank sensor
  • The cam or crank circuit is open or shorted
  • The timing belt/chain is out of time
  • The cam or crank tone ring is slipped/broken
  • A problem in the VVT system
  • The PCM is faulty
Code P0018 may be accompanied  by several different symptoms. These including: an engine that runs poorly, an engine that cranks but will not start and an illuminated check engine light.
  • Perform a visual inspection of the sensors and connections.
Many problems can easily be found in the harness and connectors. So, begin your diagnosis by visually inspecting the sensors and their connections.
  • Test the sensor output
Testing the sensor varies slightly, depending on which type of sensor your vehicle uses.
    • Permanent magnet sensor: A permanent magnet sensor can be tested using an ohmmeter. Remove the sensor connector and attach the meter to the sensor terminals. Consult the manufactures repair information for the resistance specifications. Of course, a meter reading of OL measure there is an open in the sensor and it should be replaced. Next, crank the engine and watch the ohmmeter – the reading should fluctuate. You can also do this with your meter set to read AC voltage. If there is no change in the reading, the sensor is bad and should be replaced.
Line drawing of an ohmmeter connected across a position sensor to check the resistance of its winding
Testing a permanent magnet sensor
(Courtesy: autozone.com)
    • Hall Effect sensor: Using the repair information for your vehicle, determine which pin on the sensor connector is the signal return wire. Using your multimeter on the DC voltage setting, back probe the sensor wire. Attach the black multimeter cable to battery ground. Cranking the engine, you should see the voltage reading on the meter fluctuate.
Position sensor connected to a digital multimeter reading just under 5 volts
Testing a Hall Effect Sensor
(Courtesy: autorepairhelp.us)
Note that a damaged or improperly aligned tone ring will also prevent proper sensor operation. When in doubt, remove the cam gear and the crankshaft harmonic balancer and inspect the tone rings.
  • Test the sensors circuits
If the cam and cranks sensor check out OK, but you still have P0018 code illuminated, you’ll need to check the sensor circuit.
    • Permanent magnet sensor: A permanent magnet sensor produces its own voltage, so it will only have two wires going to it – ground and return signal. Start by consulting the wiring diagram for your vehicle to determine which pin on the connector is signal and which is ground. Next, connect the red multimeter lead to the battery positive terminal and the black lead to the ground pin. You should see a reading of about 12 volts indicating a good ground. If not, you’ll need to consult the ground side of the wiring diagram to find where the circuit fault lies. Next, check that there is continuity to the PCM. You can do this by touching one meter lead to the return signal pin on the sensor connector and the other to signal pin on the PCM. Set your meter to the ohms setting – you should see a value appear on the screen. If instead, your meter reads OL, you have an open circuit and will need to trace the factory wiring diagram.
    • Hall Effect Sensor: A Hall Effect Sensor has three wires: signal, reference and ground. Start by consulting the wiring diagram for your vehicle to determine which pin on the connector is which. Next, connect the red multimeter lead to the battery positive terminal and the black lead to the ground pin. You should see a reading of about 12 volts indicating a good ground. Then, check that the 5-volt reference is getting to the sensor by connecting the red multimeter lead to the reference voltage pin and the other to ground. You should see a reading of about 5 volts indicating a good reference voltage. Finally, check that there is continuity to the PCM. You can do this by touching one meter lead to the return signal pin on the sensor connector and the other to signal pin on the PCM. Set your meter to the ohms setting – you should see a value appear on the screen. If instead, your meter reads OL, you have an open circuit and will need to trace the factory wiring diagram.
  • Test the sensor synchronization
CMP/CKP Synch status (yes/no) is displayed on many scan tools, but unfortunately, that parameter can’t always be trusted. The best way to test cam and crank sensors, as well as their synchronization, is with an oscilloscope. Increasingly more manufactures are offering sample wave form patterns in their repair information, which should be consulted before testing. The timing relationship (synchronization) of the two sensors will be distorted if a timing belt jumps time, a cam gear slips, a timing chain gets loose or a cam phaser misbehaves. Cracked reluctors and missing reluctors can also lead to an altered waveform pattern.
hook-scope
Hooking up a scope to a Hall Effect sensor
(Courtesy: autozone)
If the synchronization pattern is distorted, you need to find out why. In most cases, this will involve engine disassembly to the point of failure. Removing the timing cover and checking that the timing marks line up is one of the first things to do. Both timing belts and timing chains may stretch over time and/or have a failed tensioner.
Chart comparing crankshaft and camshaft sensor waveforms: a Hall effect sensor gives a square wave of constant amplitude, while a magnetic sensor grows in both amplitude and frequency as engine speed rises
An example of a cam and crank pattern
(Courtesy: aa1car.com)
Variable valve timing (VVT) system components can cause cam/crank correlation problems as well. These systems are often dependent on oil pressure, so checking the oil level is a good place to start. A plugged or failed oil control valve can also cause VVT problems.
vvt-system
VVT system
(Courtesy: f150online.com)
VVT solenoids can be tested for continuity or resistance with a digital multimeter. The solenoid circuit should also be tested for proper power and ground. In addition, the solenoids can also be removed and jumpered to battery voltage to confirm operation. Many scan tools also offer bi-directional testing of the solenoids with just the push of a button.
  • DTC: P0010 “A” Camshaft Position Actuator Circuit (Bank 1)
  • DTC: P0011 “A” Camshaft Position – Timing Over-Advanced or System Performance (Bank 1)
  • DTC: P0012 “A” Camshaft Position – Timing Over-Retarded (Bank 1)
  • DTC: P0013 “B” Camshaft Position – Actuator Circuit (Bank 1)
  • DTC: P0014 “B” Camshaft Position – Timing Over-Advanced or System Performance (Bank 1) – See Trouble Code P0011
  • DTC: P0015 “B” Camshaft Position -Timing Over-Retarded (Bank 1) – See Trouble Code P0012
  • DTC: P0016 Crankshaft Position – Camshaft Position Correlation (Bank 1 Sensor A)
  • DTC: P0017 Crankshaft Position – Camshaft Position Correlation (Bank 1 Sensor)
  • DTC: P0018 Crankshaft Position – Camshaft Position Correlation (Bank 2 Sensor A)
  • DTC: P0019 Crankshaft Position – Camshaft Position Correlation (Bank 2 Sensor )
  • DTC: P0020 “A” Camshaft Position Actuator Circuit (Bank 2)
  • DTC: P0021 “A” Camshaft Position – Timing Over-Advanced or System Performance (Bank 2)
  • DTC: P0022 “A” Camshaft Position – Timing Over-Retarded (Bank 2)
  • DTC: P0023 “B” Camshaft Position – Actuator Circuit (Bank 2) – See Trouble Code P0020
  • DTC: P0024 “B” Camshaft Position – Timing Over-Advanced or System Performance (Bank 2) – See Trouble Code P0021
  • DTC: P0025 “B” Camshaft Position – Timing Over-Retarded (Bank 2) – See Trouble Code P0022
Reading P0018 on your car
A basic adapter will show you P0018, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
