P0013 – Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 -circuit malfunction
P0013 | Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 -circuit malfunction (Buy Part On Amazon) | Wiring, CMP actuator, ECM |
- What Does Code P0013 Mean?
- What are the common causes of code P0013 ?
- What are the symptoms of code P0013 ?
- How do you troubleshoot code P0013 ?
- Codes Related to P0013
- Get Help with P0013
Code P0013 is defined as “Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 circuit malfunction”, and is set when a fault is detected in the electrical circuit that controls the variable valve/cam timing system. Code P0013 relates to the B, or exhaust camshaft on Bank 1, which is the set of cylinders on one side of an engine that contains cylinder #1.
The function of variable valve timing is to enable engines to develop more torque under different operating conditions. For instance, valve/cam timing can be retarded at high engine speeds to increase power output, and to reduce harmful exhaust emissions such as nitrous oxide. When the system advances valve/cam timing, fuel economy is improved under light engine loads.
In terms of the system’s operation, valve/cam timing is either advanced or retarded by the action of pressurized oil on a mechanism that forms part of the camshaft. Design specifics vary from system to system but in principle, the pressurized oil acts on an actuator to rotate the camshaft either clock-wise, or counter-clockwise relative to a base timing position to advance or retard the valve timing, depending on operating conditions such as varying loads on the engine, and throttle inputs from the driver.
The image below shows a typical oil flow control valve, with the solenoid and electrical connector making up the top part of the assembly. Note the fine wire mesh screens on the bottom part. These are essential to prevent solid particulate matter in the oil from interfering with the operation of the actuator on the camshaft.
Common causes of code P0 013 include:
- Damaged, or malfunctioning ECM.
- Defective, or malfunctioning oil flow control valve control solenoid.
- Breaks in wiring causing loss of continuity, or intermittent loss of continuity.
Common symptoms of Code P0013 are:
- Illuminated check engine warning light.
- Rough running at high engine speeds.
- Loss of power at mid, and high range RPM’s.
- Increased fuel consumption.
- Occasional stalling, especially under hard acceleration.
- Occasional hard starting.
- In some cases, there may be no noticeable symptoms apart from the illuminated check engine light, especially at small throttle openings during reduced loads on the engine.
NOTE: Symptoms of Code P0013 are of little, or no use as diagnostic aids, since these symptoms can be caused by a myriad other, unrelated issues. At best, the above symptoms can be used as confirmation of a circuit failure in the variable valve/cam timing system.
Troubleshooting Code P0013 involves a circuit check, and all diagnostic procedures must therefore include inspecting, and testing the wiring harness and control solenoid. The circuitry is relatively simple, consisting for the most part of a 12 volt DC power supply to the oil flow control valve, a ground pin to which the ECM supplies a ground at the correct time and in the correct amount, and a feedback loop to the ECM to confirm functionality.
Basic trouble shooting steps
- With the engine off, check the electrical connector on the oil flow control valve for signs of damage, looseness, and/or corrosion. Clean, replace, or repair connector as required.
Check for continuity in the wiring at the oil flow control valve. If continuity is interrupted, inspect wiring to trace breaks, and/or poor connections, and repair as required.
Check oil flow control valve solenoid resistance, and compare results with the value specified i the repair manual. Replace solenoid if resistance is out of spec.
With the engine off, remove the oil flow control valve solenoid, and apply power directly from the battery, but ensure a sound ground connection is made. Replace the solenoid if a direct power supply fails to activate the solenoid.
If a direct connection activates the solenoid, replace the solenoid, and inspect the wiring between the solenoid and the ECM for short circuits, open circuits, or high resistance. Repair as required.
If all wiring checks out OK, use a suitable scan tool to check the functioning of the oil flow control solenoid and valve. The valve should be closed during idling, but higher engine speeds will activate it. Check the status of the valve through the rev range of the engine to see if it changes from “OFF”, to “ON” as the engine speed changes. Replace the solenoid/valve if the status does not change.
In cases where the pulse width of the oil flow control valve is modulated, the active duty cycle should vary with engine speed. If this does not happen, the cause is almost certainly due to a defect or malfunction in the ECM.
In cases where the ECM delivers valid commands to the oil flow control valve, but the cam/valve timing does not return to the base timing, or where the cam phaser does not advance/retard timing sufficiently or correctly, there may be an intermittent fault in the control solenoid, or in the associated wiring. In these cases, it is advisable to replace both the oil flow control solenoid, and the entire harness that controls it. If the fault persists, have the ECM tested if possible, or replace the ECM.
Codes related to P0013 are:
- P0014: Relates to B (Exhaust) Camshaft Position, where the cam timing is over-advanced on Bank 1. This code could also be set as the result of a performance failure in the system.
- P0015: Relates to the B (Exhaust) cam timing being over-retarded on Bank 1.
- P0023: Relates to a circuit failure in the B (Exhaust) camshaft actuator on Bank 2.
- P0024: Relates to A (Exhaust) cam timing being over advanced on Bank 2. The code could also be set as the result of a performance failure in the system.
- P0025: Relates to A (Exhaust) cam timing being over-retarded on Bank 2.
Please can you speak spanish I need your help, but I not understand much the Inglish, I have mi car bad Isuzu Ascender 2005 p0013 please help me .. ride in spanish..
Replace the camshafts Illinois sensor P0013 and check engine light is still on
Justin-
Year, Make, Model, Engine? Replacing the sensor won’t address the actuator problem. The ECM uses the sensor to verify that the actuator is functioning. I’m not sure what you’re working on, but there’s likely a 2- or 3-wire solenoid valve that controls oil flow to the VVT actuator. If this is disconnected, burnt out, or the wire is cut or corroded, the ECM can’t control it. With the repair manual and wiring diagram, you should be able to determine which wires to test and how to determine if the valve is electrically functional.
Hi there, I had P0013 error. Opened up both the VVT Solenoids, cleaned up lot of debris, checked continuity of Solenoids. Reset the code. Now P0013/ P0014 comes on occasionally. Next planning to check Solenoids resistance, Solenoids actuation, wiring and the fuses. Any advise?
Hello. The checking of wiring, and fuses highly recommend that first. I would trace the resistances of these wiring harnesses back to the pcm where they receive there voltage signal. What I think probably is or could be the culprit is, hear me out. Attached to this code description is OCV valve open or short. That tells me right there where to check. The oil control valve connector, wiring for corrosion, debris. And then to check the oil control valve to see if it needs replacing. The proper resistance of this circuit is between 6.9-7.9 ohms. Also, I think this code can be set when the oil is pretty low, and the oil control valve is trying to suck as much oil up to the lifters so hard, that it runs rough and thus sets this code. But my main advice to you is do the visual inspection, check the oil, and check the ocv circuit resistances. And th ocv valve itself. Good luck and hope this is what fixes the code.
I drive my chevy 342 miles with my check engine light on, got it checked out and it came up POO13, Drove it back home [ANOTHER 342] and nothing happened
poo13 _ poo23_ poo141 this ended up being a bad 20 amp fuse going to trac. control which apparently supplyed power to cam timing circuits as well.
Remember folks s&$t runs down hill when dealing multi_codes always start at the begining . And work to the tailpipe.
Hello, that was helpful, my Hemi 5.7L VVT converted Wrangler threw this code but i cant find the bank 1 exhaust camshaft to replace it, where is located?
IFyou have that oil control valve how much it will be
I want to check how oil flow control valve for Toyota corolla professional,auto for 2011 model.
confirm if you have and which branch I will get it.i live around Alexandra township in Johannesburg.
I have a 2012 Malibu. I took my car to my mechanic and they said upon a quick check the car is throwing P0013 and P0014 sensor errors. What is the cost to repair these types of issues?
Thank you,
Tina
