P2645 – Rocker arm actuator A, bank 1 – open circuit
Last Updated 2016-06-07
P2645 | Rocker arm actuator A, bank 1 - open circuit | Wiring, rocker arm actuator |
HAVE HAD THIS CODE POP UP TWICE FIRST I CHANGED THE SOLENOID AND IT STOPPED NOW IT TURNED ON AGAIN DONT KNOW WHAT IT IS MAYBE IS THE WIRING BUT CANT SEEM TO FIND THE PART NO WHERE ANY SUGGESTION
Had this same issue have you found out what it is that’s causing the problem
