P2305 – Ignition coil B, secondary circuit – malfunction
Last Updated 2016-06-07
P2305 Ignition coil B, secondary circuit - malfunction Wiring, ignition coil
BAT Team Discussions for P2305
  • 03 Stratus, get check engine light
    The part I am using is made by ECHLIN. #IC49. The car has the 2. 4 OHDC. with 79,000 miles. Printout I received from tech says code: P2305 Ignition Coil B Secondary C. I believe there is a bulletin out for this problem but I do not know how to access it. Do you? Please Help!...
