P2270 – O2 Sensor Signal Biased or Stuck Lean B1S2
Last Updated 2017-03-15
P2270 | Heated oxygen sensor (H028) 2, bank 1 - signal stuck lean (Buy Part On Amazon) | Wiring, H025, fuel pressure, injectors, intake leak |
What Does Code P2270 Mean?
The catalytic converter is an emissions-control device. Once heated, at least 600 °F, the catalytic converter oxidizes exhaust gases into safer compounds. Most vehicles use a three-way catalytic converter (TWC), which are able to catalyze nitrogen oxides (NOx), carbon monoxide (CO), and unburnt hydrocarbons (HC). Unburned hydrocarbons (fuel) and oxygen combine, producing carbon dioxide, and nitrogen-oxides recombine, producing inert nitrogen and oxygen, for example.
The ECM (engine control module) monitors catalyst function by measuring oxygen levels in the exhaust after the catalytic converter. Ford even calls the post-cat heated oxygen sensor (HO2S) the Catalyst Monitor Sensor. A normally-functioning TWC will effect a change in oxygen content downstream as it chemically combines various exhaust components, resulting in a slowly variable HO2S reading downstream, slowly cycling between 0 V and 1 V. The ECM regularly tests TWC function by boosting fuel at a predetermined interval. If the HO2S does not respond with voltage over a certain threshold, indicating lower oxygen content, the ECM determines this to be a fault, sets a diagnostic trouble code (DTC) and illuminates the malfunction indicator lamp (MIL). DTC P2270 is defined as “O2 Sensor Signal Biased or Stuck Lean B1S2.”
What are the common causes of code P2270?
Depending on year, make, and model, DTC P2270 may have number of causes. Here are some of the most common.
- Ford TSB – There is at least one Technical Service Bulletin that covers this DTC, requiring the replacement of the HO2S. There is an updated part number for some 2010-2012 Ford 4.6L, 5.4L, 6.2L, and 6.8L engines.
- Exhaust leaks, contaminated HO2S, and loose HO2S are the most common failures notes.
- Rarely, incorrect fuel pressure, leaking fuel injectors, or faulty EVAP purge control valves may cause this problem.
Images
Oxygen vs Voltage by Clamothe via Wikimedia
Catalytic Converter by Stahlkocher via Wikimedia
What are the symptoms of code P2270?
You will probably not notice any drivability symptoms, though your fuel economy may suffer if the failure mode puts the engine in open-loop mode.
How do you troubleshoot code P2270?
Though this DTC refers to an oxygen sensor, do not simply replace it as a matter of course. The sensor may be at fault, but do not condemn it unless you have done the rest of the tests. If there are multiple DTCs, including history codes, address those DTCs first, reset the ECM, and see if DTC P2270 comes back.
- Exhaust Check
- Check that there are no exhaust leaks between the engine and the HO2S. Repair as necessary.
- Check that the HO2S is installed properly and undamaged. Adjust or replace as needed.
- Sensor Check –
- Check that the connector is free of corrosion or water entry. Repair as needed and ensure connector is fully seated.
- Remove sensor and check for contamination, such as from oil or coolant. Repair as needed and recheck the system.
Codes Related to P2270
P2195 O2 Sensor Signal Biased/Stuck Lean Bank 1 Sensor 1
P2196 O2 Sensor Signal Biased/Stuck Rich Bank 1 Sensor 1
P2197 O2 Sensor Signal Biased/Stuck Lean Bank 2 Sensor 1
P2198 O2 Sensor Signal Biased/Stuck Rich Bank 2 Sensor 1
P2271 O2 Sensor Signal Biased/Stuck Rich Bank 1 Sensor 2
P2272 O2 Sensor Signal Biased/Stuck Lean Bank 2 Sensor 2
P2273 O2 Sensor Signal Biased/Stuck Rich Bank 2 Sensor 2
P2274 O2 Sensor Signal Biased/Stuck Lean Bank 1 Sensor 3
P2275 O2 Sensor Signal Biased/Stuck Rich Bank 1 Sensor 3
P2276 O2 Sensor Signal Biased/Stuck Lean Bank 2 Sensor 3
P2277 O2 Sensor Signal Biased/Stuck Rich Bank 2 Sensor 3
