P2262 – Turbocharger (TC) boost pressure not detected
| P2262 | Turbocharger (TC) boost pressure not detected (Buy Turbocharger boost pressure not detected On Amazon) | Mechanical fault |
Reading P2262 on your car
A basic adapter will show you P2262, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
We have not gotten around to publishing a technical guide specifically for P2262 – Turbocharger (TC) boost pressure not detected yet.
Triggering a limp mode event in drive with surging and wont pass 1500 rpm. Hard idle while in park and with turbo spooling slightly hearing whistle. In park wont rev past 1800 rpm and no surging.Triggered with P0471 P2563
