P2201 – Nitrogen oxides (NOx) sensor, bank 1 – range/performance problem
| P2201 | Nitrogen oxides (NOx) sensor, bank 1 - range/performance problem (Buy Part On Amazon) | Wiring, NOx sensor |
- What Does Code P2201 Mean?
- Where is the P2201 sensor located?
- What are the common causes of code P2201?
- How expensive is it to fix code P2201?
- What are the symptoms of code P2201?
- What are common solutions to code P2201?
- How serious is code P2201?
- How difficult is it to repair code P2201?
- Get Help with P2201
OBD II fault code P2201 is a generic trouble code that is defined as P2201 – “Nitrogen oxides (NOx) sensor, bank 1 – range/performance problem”, and is set when the PCM (Powertrain Control Module) detects an abnormal or unexpected signal from the NOx sensor on bank 1, which is the bank of cylinders on V-type engines that contains cylinder #1.
The function of NOx sensors on diesel and gasoline vehicles is to measure the level of oxides of nitrogen present in the exhaust stream.
The combustion process in all internal combustion engines can cause oxygen to combine with nitrogen under certain operating conditions, and as a general rule, diesel engines produce higher levels of NOx (short for oxides of nitrogen) than gasoline engines. It is worth pointing out that NOx has toxic properties that can cause a wide range of serious health conditions in humans that include but are not limited to heart attacks, respiratory failure, and some forms of cancer.
To reduce the levels of NOx that vehicle engines emit in order to meet emission regulations, manufacturers have introduced a range of exhaust after-treatment technologies that convert NOx into pure nitrogen and oxygen. We need not delve into the complexities of all current diesel exhaust after-treatment technologies here but suffice to say that even advanced systems like Selective Catalytic Conversion cannot remove all NOx from the exhaust system.
Thus, all modern diesel vehicles are fitted with dedicated sensors to measure the level of NOx in the exhaust as that exits the Selective Catalytic Converter. In most cases, the vehicle is fitted with two Nox sensors; one upstream of the Selective Catalytic Converter, and another close to the outlet of the Selective Catalytic Converter. This arrangement allows the NOx controller (a dedicated control module) to compare the levels of NOx that enter the Selective Catalytic Converter with the levels of NOx that exit the Selective Catalytic Converter as a means of assessing the efficiency of the converter.
It is worth noting, though, that some vehicles have only one Nox sensor, which is usually located close to the Selective Catalytic Converter.
In terms of operating principles, NOx sensors are supplied with a reference voltage that changes in a direct response to the level of NOx in the exhaust gas. The NOx sensor generates a signal voltage based on the level of NOx in the exhaust gas, and this signal voltage is sent to the NOx controller, which then corrects the air/fuel mixture to a stoichiometric* ratio to reduce the level of NOx in the exhaust stream.
* 14.7 parts of air to one part of fuel in gasoline engines, and 14.5 parts of air to one part of fuel in diesel engines.
Note that on Selective Catalytic Reduction systems that use DEF (Diesel Exhaust Fluid, aka AdBlue) the NOx controller will also command the DEF injection system to inject a precisely calculated amount of fluid into the catalytic converter to assist with the conversion of NOx into nitrogen and oxygen.
From the above, it should be clear that NOx sensors play a critically important role in the larger emission control systems of modern engines, especially on modern diesel engines. Thus, when the PCM detects an abnormal/ implausible/unexpected/inaccurate signal voltage in any circuit that is associated with the NOx sensor(s) based on current operating conditions, it will recognize that it cannot control the level of NOx emitted by the engine effectively. If this happens, the PCM will set fault code P2201, illuminate a warning light, and will usually, but not always also initiate a failsafe or limp mode to limit the engine’s power output to reduce emissions.
The images below show the locations of both the upstream and downstream NOx sensors on a 2011 Mercedes 350 ML.
Note that accessing either NOx sensor as shown here requires the removal of all splash guards under the vehicle as well as the heat shield(s) that enclose the catalytic converter. Although it is possible to remove these guards and shields on a DIY basis, but be aware that it is a difficult and time-consuming task that can take between 4 and 5 hours to complete if you do not have access to a vehicle lift or hoist.
NOTE: The large red arrows point to the rear of the vehicle, thus indicating the direction of flow through the exhaust system.
Common causes of code P2201 could include one or more of the following-
- Defective or malfunctioning NOx sensor (Common cause)
- Mechanical damage to the sensor caused by impacts with road debris or other objects
- Water intrusion into the sensor(s)
- The use of Incompatible or unauthorized oil and fuel additives that could damage the sensitive ceramic sensing element of modern NOX sensors
- Excessive oil consumption that could cause a build-up of carbon or soot on the sensor’s sensing element
- Leaking fuel injectors that could overwhelm the sensor’s sensing elements with unburned hydrocarbons
- Large temperature fluctuations that could cause damaging thermal shocks
- Damaged, burnt, shorted, corroded, or disconnected wiring or electrical connectors anywhere in any electrical circuit that is associated with the NOx sensor or NOx controller
- The use of substandard, unsuitable, or incorrect aftermarket NOx sensors
NOTE: Damaged or fouled NOx sensors cannot be repaired or cleaned reliably, so if you suspect that a NOx sensor has failed, the only reliable remedy is to replace the sensor with an OEM or OEM-equivalent part to ensure the proper operation of the sensor.
Replacing NOx sensors even on a DIY basis can be costly, as the retail prices of NOx sensors range from about $250 to as high as $750, depending on both the brand of the sensor and the affected vehicle.
Having the replacement performed at a professional repair shop could about 1 hour’s labor, but bear in mind that the procedure could also require some diagnostic time and related repairs such as replacing damaged wiring.
As a practical matter, though, it is not possible to provide accurate repair estimates here so we strongly recommend that you consult with several repair shops to obtain an accurate repair estimate that includes the cost of a high-quality NOx sensor, as well as all charges, levies, taxes, and fees that are payable in your location. Failing to do this could leave you with a repair bill that is higher than you are willing or prepared to pay.
Common symptoms of code P2201 could include one or more of the following-
- Depending on both the nature of the problem and the vehicle, multiple additional emissions-related codes may be present along with P2201
- The vehicle may be in a limp mode that will persist until the fault is corrected
- A no-start condition may be present
- Fuel consumption may increase noticeably
- If the vehicle is not in limp mode, engine power may be reduced significantly to reduce emissions
Some possible DIY solutions to resolve code P2201 could include the following-
- Inspect all relevant wiring for signs of damage, and repair as required
- Inspect the NOx sensor for evidence of physical damage, and replace the sensor with an OEM or OEM-equivalent sensor if required
- If any kind of aftermarket oil additives are present in the engine oil, perform an oil change (including replacing the oil filter) to prevent a recurrence of the problem
- If any kind of aftermarket fuel additives, including injector cleaner(s) are present in the fuel, fill the fuel tank to dilute the additives. Doing this may prevent a recurrence of the problem
- If the affected NOx sensor is accessible and you have the special tool required to remove it, replace the damaged sensor with an OEM or OEM-equivalent part, but ensure that the part numbers on the old and new sensor match exactly. Mismatched part numbers can cause a continuous recurrence of the problem
In all cases, code P2201 must be considered as serious because it could cause sudden and severe drivability issues at any time and without any warning, which poses a significant safety risk to both the vehicle’s occupants and other road users.
Since there are many possible causes of code P2201, we do not recommend that non-professional mechanics attempt any diagnostic or repair procedure for code P2201 beyond the few steps outlined in the previous section of this guide.
Since ill-considered or incorrect test procedures could cause significant and even serious damage to the affected vehicle’s electrical system, we strongly recommend that you seek professional assistance with diagnosing and resolving code P2201 on any vehicle.
Reading P2201 on your car
A basic adapter will show you P2201, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
