P2192 – System too rich at higher load, bank 1
Avatar photo
By Jessica Howe (Contact Me)
Last Updated 2019-09-26
ASE Mechanic
P2192 System too rich at higher load, bank 1
Fuel pressure, injectors, air intake restricted
  1. What Does Code P2192 Mean?
  2. Where is the P2192 sensor located?
  3. What are the common causes of code P2192?
  4. What are the symptoms of code P2192?
  5. What are common solutions to code P2192?
  6. How serious is code P2192?
  7. How safe is it to still drive the car with code P2192?
  8. What are the common mistakes when repairing code P2192?
  9. How do you troubleshoot code P2192?
  10. Codes Related to P2192
  11. Get Help with P2192
The P2192 code is very specific and can be broken down in order to fully understand it. “System too rich” indicates that there is excess fuel being added to the fuel/air intake. “at higher load” indicates this rich fuel/air mixture is only being detected when the engine is working harder (at higher RPMs,  going up steep hills, or while towing).  “Bank 1” indicates what part of the engine this is being detected in. Bank 1 is the side of the engine where cylinder number 1 is found.
Bank 1 describes the side of the engine that houses the number 1 cylinder on a V-shaped engine. Straight or inline engines only have one bank, and therefor a P2192 code pertains to the entire engine.
  • Failing oxygen sensor
  • Failing fuel injector
  • Faulty fuel pressure regulator
  • Faulty mass airflow sensor
  • Powertrain control module issue
  • Check engine light
  • Lack of acceleration under a heavy load
  • Misfiring
  • Decreased fuel mileage
Resolving the code may be as simple as replacing a faulty sensor, like an oxygen sensor or the mass airflow sensor, or it may be a more complicated fuel related issue.
The seriousness of this code will be determined by the vehicle’s performance. If the vehicle is driving like normal, you likely have more time to get the issue fixed. If the vehicle is suffering from other symptoms, you will want to have the problem resolved as soon as possible.
There are no direct threats present from driving a vehicle with a P2112 code present. If the vehicle is demonstrating other more serious symptoms, you may have driving issues and need to avoid using the vehicle.
Although it may seem like you have a code that is indicating a fuel-related issue, you are more likely to have an issue with the sensors that are needed to regulate the fuel/air mixture. Start with double checking the mass airflow sensor and the oxygen sensors first. Then you can spend time diagnosing a more serious fuel trim issue.
Diagnosing a P2192 starts with comparing any an all other DTS (diagnostic troubleshooting codes) that are present or pending. Any code that pertains to the oxygen sensors, mass airflow sensor, or the fuel trim should take priority. Start by checking that particular system first.
A scan tool can also be used to test the oxygen sensor, or to monitor it, to see if it is working correctly or not. The same can be done with the mass airflow sensor and the manifold absolute pressure sensor (which may be one sensor on newer models).  Replace the sensor that is not working correctly if needed.
If the issue is truly fuel pressure related, you will want to check for pressure at the fuel rail. If the fuel pressure is in an appropriate range, you will want to check the individual fuel injectors on bank 1 of the engine.
  •  P2190: System Too Rich at Idle
  • P2191: System Too Lean at Higher Load Bank 1
  • P2198: O2 Sensor Signal Biased/Stuck Rich
  • P0101: Mass Airflow Sensor Circuit Range/Performance
Reading P2192 on your car
A basic adapter will show you P2192, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
