P2188 – System too rich at idle, bank 1
Last Updated 2018-03-08
P2188 | System too rich at idle, bank 1 (Buy Part On Amazon) | Fuel pressure, injectors, air intake restricted |
What Does Code P2188 Mean?
OBD II fault code P2188 is a generic code that is defined as “System Too Rich at Idle Bank 1”, and is set when the PCM (Powertrain Control Module) detects too much fuel relative to air in the air/fuel mixture when the engine is idling. Note that “bank 1” refers to the bank of cylinders that contains cylinder #1 on V-type engines.
NOTE: Note that code P2188 refers specifically to a rich-running condition when the engine is idling. If a rich-running condition is detected at engine speeds above idling speeds, this condition will be indicated by one or more codes other than P2188.
Since gasoline engines are most efficient when the air/fuel mixture consists of 14.7 parts of air to one part of fuel (the stoichiometric ratio), all applications use a dedicated sensors to monitor both the volume and temperature of the intake air in real time. The PCM then uses this input data to calculate how much fuel it needs to inject to maintain the air/fuel mixture at a ratio as close to the stoichiometric ratio as possible to suit any given set of operating conditions, based on input data from several other sensors, such as the throttle position sensor(s), among others.
Oxygen-, or air/fuel ratio sensors in the exhaust system monitor the concentration of oxygen relative to other gases in the exhaust stream, since the oxygen content of the exhaust stream is a reliable indicator of the composition of the air/fuel mixture prior to combustion. However, note that these sensors can only supply an accurate reading if the oxygen-, or air/fuel ratio sensors and their control systems are themselves in perfect working condition, and that there are no misfires, vacuum leaks, exhaust leaks, excessive oil consumption due to mechanical issues, or defects in the ignition system present on the engine.
Thus, assuming that the engine is in perfect condition, the PCM’s on most applications are able to make minor adjustments to various systems to compensate for slight differences between the actual and desired air/fuel ratios that sometimes occur when some sensors begin to lose their sensitivity after long use. However (regardless of the manufacturer), since a PCM’s ability to make adjustments to fuel injector pulse widths, ignition timing, and other systems to compensate for the loss of sensor sensitivity is limited, it will set code P2188 and may also illuminate a warning light when it recognizes that it can no longer control the air/fuel mixture effectively.
Where is the P2188 sensor located?
The image above shows a MAF (Mass Airflow) sensor in which the actual sensing element (circled) is heavily contaminated with engine oil, which is a common cause of air/fuel mixture problems, and especially on applications such as BMW, Mercedes, and VAG-group vehicles that are known for their high oil consumption rates. Note however, that since a contaminated, dirty, or defective MAF sensor is only one possible cause of code P2188, it is important to refer to the manual for the affected application for details on the most likely causes of code P2188 on that application.
On all applications that use a MAF sensor, the sensor is located in the inlet tract between the air filter box and the throttle body.
What are the common causes of code P2188?
Note that depending on the application and both its fuel and induction systems, the possible causes of this code can be either electrical or mechanical, or in some cases, both electrical and mechanical, such as an EVAP purge valve that is stuck in the open position. Therefore, it is important to record all fault codes and freeze frame data (if present), and to resolve all additional codes in the order in which they were stored before an attempt is made to diagnose P2188 to avoid a misdiagnosis. Nonetheless, some common causes of code P2188 could include the following-
- Damaged, burnt, shorted, disconnected, or corroded wiring and /or connectors associated with any sensor(s) related to the air/fuel metering system
- Defective oxygen sensor(s)
- Defective air/fuel ratio sensor(s)
- Exhaust or engine vacuum leak(s)
- Excessive fuel pressure
- Defective fuel injectors
- Excessive oil consumption
- Defective EVAP system
- Failed or failing PCM, but note that this is rare event and the fault must therefore be sought elsewhere before any control module is replaced
These codes are pulling up on my car a p2188 p0172 the other is for a camshaft position sensor a circuit bank 1 or single sensor number for Aristotle pedal positioning sensor switch A and B voltage correlation I have no idea what’s going on here how much is this going to cost and where do I go I am poor I was told that all that was wrong with this car was tires
Hi There, I have a VW Passat CC 2011. I occasionally have misfires after driving for approximately 2 hours. Eventually the car cuts off. I changed the high pressure fuel pump, O2 Sensors and PCV Valve. I have no check engine light on the dash. What do you think can be the issue here?
Greetings. I have seen this in another make and model, however the idle really fluctuated up and down continuously and surged to no end. Have you checked your fuel pressure? Make sure that is within specifications before you go any further. Next, check your air vacuum pump. German cars have a strange air injection pump that most domestic cars do not. If this okay, and you don’t have any vacuum leaks, I would look at replacing your M.A.P sensor. This would cause it to die after continuous running. Make sure the tip of the sensor is not covered in oil. If so, it is defective. Normal readings should be between 3-14 hg. Grams per minute that is. Also the sensor should be readimg at or close to 5 volts. Hope this helps.
What Year – Make – Model?
What’s the first I should check when this code comes up? No other codes with it
08 Mini S R56 turbo hatch. Persistant intermittant p2188. Drivabily is great. Occasional stumble on start but code not set at time of stumble. Plugs look perfect. Vacuum lines recently replaced. ne change, Vanos replaced no change. Valve vover with plugged EGR replaced. No change. Rail pressure in normal range. ????
