P2185 – Engine coolant temperature (ECT) sensor 2 – circuit high
| P2185 | Engine coolant temperature (ECT) sensor 2 - circuit high (Buy Part On Amazon) | Wiring short to positive, ECT sensor |
Where is the Engine coolant temperature sensor (ECT)? See our guide to the Engine coolant temperature sensor (ECT) – what it does, where it sits on the engine and how it fails.
- What Does Code P2185 Mean?
- Where is the P2185 sensor located?
- What are the common causes of code P2185?
- What are the symptoms of code P2185?
- Get Help with P2185
OBD II fault code P2185 is a generic code that is defined as “Engine Coolant Temperature (ECT) Sensor 2 – Circuit High”, or oftentimes more precisely as “Coolant Temperature Sensor at Radiator Outlet Signal High” and is set when the PCM (Powertrain Control Module) detects an abnormally high voltage either in the affected sensor itself, or in the affected sensor’s control/signal circuit(s).
SPECIAL NOTES: It should be noted that some applications use multiple (more than two) engine coolant temperature sensors for different purposes, and in the case of code P2185, the affected engine coolant temperature sensor is usually associated with the radiator cooling fan(s). However, be aware that not all car manufacturers follow this convention, which means that on some applications, code P2185 could refer to a sensor that is associated with other functions, such as fuel delivery, fuel injector pulse width management, or the operation of the heat gauge in the dashboard. For this reason, it is imperative that the correct sensor be identified when this code appears on any given application to prevent misdiagnoses. END OF SPECIAL NOTES.
Nonetheless, if we take the most common definition of code P2185 to be “Coolant Temperature Sensor at Radiator Outlet Signal High”, the function of the affected sensor is to monitor the temperature of the engine coolant at the radiator outlet, from where the cooled coolant is passed back into the engine.
In a fully functional cooling system, the flow or circulation of the coolant is managed by a thermostat, which either opens or closes in response to the temperature of the engine coolant. Thus, assuming that the thermostat is working as designed, the coolant is circulated in such a way that the hot coolant enters the top of radiator, and exits the radiator at the bottom after having shed much of its heat to the atmosphere.
As a practical matter though, the PCM needs to “know” exactly how hot the coolant is when it exits the radiator in order to be able to control both the speed and duty cycle (“ON” time) of the cooling fans, which greatly increases the efficiency of the cooling process, and to provide the PCM with this information, the #2 coolant temperature sensor is located close to the radiator outlet.
In terms of operating principles, the coolant temperature sensor is supplied with a 5-volt reference voltage by the PCM, which voltage changes when a fixed resistance in the sensor changes in a direct response to changes in the temperature of the coolant. For instance, when the coolant is cold, the sensor’s resistance is high, and less current is passed back to the PCM via a dedicated signal circuit. Conversely, as the coolant’s temperature rises, the sensor’s resistance decreases, and progressively more current is fed back to the PCM via the same dedicated signal circuit.
The PCM then compares the changes in the signal voltage to pre-programmed look-up tables and calculates an actual coolant temperature based on the length of time the engine had been running, the temperature of the intake air, and the actual value of the signal voltage it receives from the sensor.
When the PCM calculates that upon exiting the radiator the coolant’s temperature approaches or exceeds a maximum allowable threshold, it will activate the radiator fans to speed up the cooling of the engine coolant, and in a fully functional cooling system, the coolant may be cooled down to the point where the thermostat closes, and the radiator cooling fans are deactivated. When this happens, the coolant stops circulating until it has absorbed sufficient heat from the engine for the thermostat to open again to restart the coolant circulation and cooling process.
However, if a defect, malfunction, or failure occurs anywhere in the cooling system that influences how the PCM calculates the actual engine coolant’s temperature at the radiator outlet, the PCM will recognize that it cannot manage the engine’s temperature effectively, and it will set code P2185 and illuminate a warning light as a result.
NOTE: One example of such a defect, malfunction, or failure would be a thermostat that is stuck in the closed position. If this happens, the engine coolant can heat up through convection to the point where the coolant is much hotter at the radiator outlet than it would have been had the thermostat worked correctly, which would generate a higher than expected signal from the #2 sensor, given the length of time the engine had been running.
The image above shows the location of the #2 engine coolant temperature sensor close to the outlet of the radiator on an E46 BMW application, but on many applications, this sensor can also be located in the bottom tank of the radiator. Note though that in all cases, the sensor will be located so that it is in direct contact with the engine coolant.
Some common causes of code P2185 could include the following-
- Damaged, burnt, shorted, disconnected, or corroded wiring and/or connectors in the #2 sensor’s wiring harness. Note that short circuits to battery positive is a common case of this code
- Defective coolant temperature sensor
- Use of aftermarket coolant temperature sensors
Some common symptoms of code P2185 could include the following-
- Multiple additional codes, and particularly codes relating to the cooling system may also be present
- Radiator fans may run consciously, or not at all regardless of the actual coolant temperature
NOTE: Be aware that the engine could overheat fatally when this code is present, since this sensor is generally not involved in the display of the engine temperature on the dashboard. In translation, this means that an engine can overheat due to the radiator fans not working, or not working properly, even though the indicated engine temperature reading may be normal on the dashboard. Be aware that in most cases of engine overheating, the damage is already done by the time the temperature gauge registers an abnormally high reading, which is why all cooling system related warning lights should be taken very seriously.
Reading P2185 on your car
A basic adapter will show you P2185, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
Hi, I have a honda 2005 CRV with the code P2185,I did replace both sensors did continuity test on ground and supply wires back to ECU all good.try errasing erro via my ottofix scanner but engine check light is still displays and car starts and dies again.Your feedback and assistance is appreciated.
Thank you
Sala Nau
