P2176 – Throttle actuator control (TAG) system – idle position not learned
BAT Team
Last Updated 2016-06-07
P2176 Throttle actuator control (TAG) system - idle position not learned Basic setting not carried out
BAT Team Discussions for P2176
  • 05 Caddy SRX not starting, Part Deaux
    Try this: Idle Learn Procedure from the shop manual; Description The engine control module (ECM) learns the idle position of the throttle body to ensure the correct idle operation. Anytime the ECM or the throttle body is replaced, the ECM must learn the idle position. The engine idle may be unsta...
  • 08' Chevy Avalanche check engine light on with decreased gas milage
    More detailed information... DTC P1174 or P1175 Diagnostic Instructions - Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. - Review Strategy Based Diagnosis for an overview of the diagnostic approach. - Diagnostic Procedure Instructions provides an ...
  • 2005 Cadillac SRX (Reposted from TroubleCodes.net)
    Hey guys I have a 2005 Cadillac SRX AWD V8 with 3 misfire codes registering with obd2 P0301, P0302, and P0308. Is there any chance with this many codes registering misfire and a reading that shows 11 problems and a second obd that registered 16 problems, that maybe the firing order has been changed ...
