P2170 – Exhaust gas pressure regulator vent solenoid – circuit low
BAT Team
Last Updated 2016-06-07
P2170 Exhaust gas pressure regulator vent solenoid - circuit low Wiring short to ground, exhaust gas pressure regulator vent solenoid
BAT Team Discussions for P2170
  • Low coolant light but temp gauge reading ok
    work the P0302 first as Jim mentioned a misfire likely causes- the P1131 is a probleem with B1S1 the reading is frozen. were those p2170 and 2271 active? with a scanner that sees data not to bad to do - p0136 bank 1 sensor 2 post cat- p0174 is bank 2 and the upstream before cat....
