P2135 – Accelerator pedal position (APP) / Throttle position (TP) sensor/switch A/B – voltage correlation
Last Updated 2016-08-29
The Automotive Copywriter
P2135 | Accelerator pedal position (APP) / Throttle position (TP) sensor/switch A/B - voltage correlation | Wiring, APP / TP sensor/switch / Wiring, TP sensor/switch |
What Does Code P2135 Mean?
Largely, vehicle manufacturers have switched from cable-operated throttle bodies to electronically-controlled throttle body designs. Known as drive-by-wire, these systems use a sensor at the accelerator pedal to determine its position. Then, a signal is sent to a sensor on the throttle body to adjust the position of the throttle plate. This action is performed in real-time, and response is virtually instantaneous. The throttle body has two throttle position sensors (TPS) sensors that provide a voltage signal to the powertrain control module, along with a 5V reference circuit an a common low-reference circuit. The two TPS sensors operate inversely -- one has an increasing voltage when throttle is applied and one has decreasing voltage on throttle application. If the two TPS sensor readings don't correlate in the PCM for more than a couple seconds, DTC P2135 is set in the PCM.What are the common causes of code P2135?
- TPS failure (most common concern)
- Poor connection or bent pins in TPS connector
- Chafed or corroded wiring
- APP sensor failure
- PCM internal short (least likely but possible)
What are the symptoms of code P2135?
- Hard starting
- Little to no throttle response
- Check Engine light illuminated
- Sudden loss of engine power while driving
- Possible stalling condition when slowing to a stop
How do you troubleshoot code P2135?
Before attempting to diagnose and repair the concern, determine if your vehicle is involved in a service bulletin from the manufacturer. Many General Motors vehicles have a TSB extending the coverage on throttle body side cover replacement to repair a condition such as this. It's also a known issue on many Nissan vehicles. The TPS system is made up of three main components that communicate for accurate throttle response: the accelerator position (APP) sensor, the TPS sensor, and the powertrain control module (PCM). Diagnosing DTC P2135 can be achieved with just a digital volt-ohmeter to measure resistance, and vehicle-specific wiring diagrams that you can obtain from major parts retailers or the dealer. DTC P2135 is set when there is high resistance on any of the four wires to the TPS sensor. With the ignition off, test for resistance between the low-voltage reference circuit and ground. If resistance is higher than 5 ohms, check the circuit for corrosion or chafed, cracked, or loose wires or connectors. With the ignition on, test for 5V reference voltage. The value should be between 4.8 and 5.2V. Higher voltage indicates a short to voltage while low reference voltage indicates a short to ground or open in the circuit. Trace for those issues. Test voltage at the TPS connector for each signal circuit, one at a time. One signal circuit should remain below 1V without throttle input. Slowly apply throttle, monitoring the voltage for a smooth increase. Wide open throttle (WOT) should near 5V. The second signal circuit should maintain at or near 5V with no throttle application. On smooth pedal application, the voltage should drop until WOT results in near 0V. If either of the signal circuits spike when the accelerator is pressed, the TPS needs to be replaced. Many TPS are serviced as part of the throttle body assembly.
Codes Related to P2135
- P0120 – Throttle position (TP) sensor A/accelerator pedal position (APP) sensor / switch A -circuit malfunction
- P0122 – Throttle position (TP) sensor A/accelerator pedal position (APP) sensor / switch A -low input
- P0123 – Throttle position (TP) sensor A/accelerator pedal position (APP) sensor / switch A -high input
- P0220 – Throttle position (TP) sensor B/accelerator pedal position (APP) sensor / switch B -circuit malfunction
- P0222 – Throttle position (TP) sensor B/accelerator pedal position (APP) sensor / switch B -low input
- P0223 – Throttle position (TP) sensor B/accelerator pedal position (APP) sensor / switch B -high input
BAT Team Discussions for P2135
- 2004 Ford Explorer
2004 Ford Explorer, XLT Pkg.. 4.0 SOCH V6, 83K miles, 2wd, 5-speed automatic, no towing package CEL came on along with service vehicle light. Vehicle drove the same. About two days ago, CEL whent off, but vehcile started hesitating and when you step on the gas it hesitates.. Pulled codes tonight, g... - P0455 AND P2135
Please help! Our truck keeps having these codes come up and the dealer fixed something a while ago and now its happening again. What would fix this problem? The last time it happened they changed the TPS-throttle positioning sensor-it was a yellow wire- they repaired it. Can someone help me? Cod... - random missfire 2.2L echotech chevy cobalt
A 2005, 06, 07? Always post the code number- often times descriptions are incorrect- Are you capable of scanning higher # codes- manufacturer specific ie p2135 p2138? Vehicle is STOCK no add ons or aftermarket? alarm Remote? New plugs are AC delco- how did old plugs look? I see some ... - 2004 grand prix P0496
Here is some info on it that might help you...Jim............DTC P0496 SYSTEM DESCRIPTION This DTC tests for undesired intake manifold vacuum flow to the evaporative emission (EVAP) system. The control module seals the EVAP system by commanding the EVAP canister purge solenoid valve OFF and the E... - 05 Altima code P2135
Last weekend I made a drive 750 miles or so from IL to PA, stopping only for gas. At the end of my trip, while paying a toll, my car stalled. I started it again and it stalled again. I started it a third time and it stayed running, but pressing the accelerator only made the car move slightly and ...
