P2125 – Accelerator pedal position (APP) / Throttle position (TP) sensor/switch E – circuit malfunction
BAT Team
Last Updated 2016-06-07
P2125 Accelerator pedal position (APP) / Throttle position (TP) sensor/switch E - circuit malfunction Wiring, APP / TP sensor/switch
BAT Team Discussions for P2125
  • 2004 grand prix P0496
    Here is some info on it that might help you...Jim............DTC P0496 SYSTEM DESCRIPTION This DTC tests for undesired intake manifold vacuum flow to the evaporative emission (EVAP) system. The control module seals the EVAP system by commanding the EVAP canister purge solenoid valve OFF and the E...
  • 08' Chevy Avalanche check engine light on with decreased gas milage
    More detailed information... DTC P1174 or P1175 Diagnostic Instructions - Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. - Review Strategy Based Diagnosis for an overview of the diagnostic approach. - Diagnostic Procedure Instructions provides an ...
