P2047 – Reductant injector 1, bank 1 – open circuit
Last Updated 2016-06-07
P2047 | Reductant injector 1, bank 1 - open circuit | Wiring, reductant injector |
BAT Team Discussions for P2047
- 2010 Jeep Wrangler Engine Loping
A scan tool shines here for intermittents or as you are describing, cold problems that disappear (or so they seem) when hot. A scan tool will tell you if you have pending codes waiting. When you idle problems goes away, that discrepancy is stored and if still present even when hot, it will trigger ... - 2004 F150 Idle Surge on Cold Start (Not normal High Idle)
http://www.ebay.com/itm/ELM327-WiFi-OBD2-Car-Diagnostics-Scanner-Code-Reader-for-iPhone-iOS-AND-Android/331175483846?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D27710%26meid%3D2f93598c55f149668a062bfedf88449d%26pid%3D100005%26prg%3D11385%26rk%3D3%26rkt%3D6... - Me and my damned projects. LCD tv repair.
Yeah, I know Bill. I spent all morning on the phone trying to find a board. Non are available. NO ONE HAS THEM IN STOCK. They all fail at that precise location. I de-soldered the fuses. That was easy enough. Readily available [URL]http://www.ebay.com/itm/10Pcs-Littelfuse-Fast-Acting-SMD-Fuse-18... - 2006 Merc Grand Marquis Steering column making clunking sound while turning?
Also, the upper bearing likes to get loose. But normally, that is accompanied with a loose steering in your hands. Anyway, don't fuss around with that, I see one going on e-bay for 34$, the part counter guy's probably know the part# by heart by now. Here are a few links to what you SHOULD buy. ... - 92 honda Accord mice chewed control box wiring wont start now !
Ok, forget what I said, found a proper link that is more in my liking. 39$cdn for a 20m roll. [URL]http://www.ebay.ca/itm/NEW-GENUINE-HONDA-ACURA-RODENT-RAT-MICE-MOUSE-PROOF-ELECTRICAL-TAPE-4019-2317/291726407330?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20161027085944%26meid%3D6e2...
Leave a Reply
