P2023 – Intake manifold air control actuator position sensor/switch, bank 2 – circuit intermittent
Last Updated 2017-12-31
P2023 | Intake manifold air control actuator position sensor/switch, bank 2 - circuit intermittent (Buy Part On Amazon) | Wiring, poor connection, intake manifold air control actuator position sensor/switch |
What Does Code P2023 Mean?
OBD II fault code P2023 is a generic code that is defined as “Intake manifold air control actuator position sensor/switch, Bank 2 – circuit intermittent”, and is set when the PCM (Powertrain Control Module) detects an intermittent open circuit or loss of continuity in the control and/or signal circuit(s) of the intake manifold air control actuator’s position sensor/switch. Note that “Bank 2” refers to the intake manifold air control actuator position sensor/switch that is fitted to the inlet manifold of the bank of cylinders that does not contain cylinder #1.
Note that code P2023 refers specifically to intermittent loss of continuity in the electrical circuits that are directly associated with the IMRC (Intake manifold air control actuator) position sensor/switch. Therefore, the probable causes of code P2023 are far more likely to only involve issues such as poor electrical connections in the position sensor’s control/signal circuits, or defects in the position sensor itself, rather than faults/defects/malfunctions in parts and components elsewhere in the intake manifold air control system.
NOTE #1: The IMRC should not be confused with a similar system that tweaks or controls inlet manifold dynamics, which effectively changes the length of individual manifold runners. Since the IMRC system controls the motion of the intake air inside the inlet manifold, the ISO/SAE recommended term for this system is “Intake Manifold Runner Control System”(IMRC), to avoid confusion, although this system is sometimes also known as the Swirl Control System/Valve or the Charge Motion Control System/Valve.
NOTE #2: Similarly, the ISO/SAE recommends that all systems/devices that control, regulate, tweak, or alter the dynamics(length, shape, or diameter) of inlet manifold runners be referred to as the “Intake Manifold Tuning (IMT) Valve”, although this system is sometimes also known as the Intake Manifold Tuning Valve, Long/Short Runner Control, or Intake Manifold Communication Control.
The purpose of the intake manifold runners is to improve the airflow inside the intake manifold by creating a restriction in the manifold at low engine speeds, both to improve engine efficiency at low engine speeds, and to reduce harmful exhaust emissions. Since combustion is typically less efficient at low engine speeds, creating a partial restriction in each manifold runner increases the airflow rate through the runners, which has the effect of eliminating manifold pressure fluctuations that are caused by the opening and closing of the inlet valves during normal engine operation.
In terms of operation, the IMRC system uses individual flaps in each manifold runner that are all connected to a control rod that runs the length of the inlet manifold. The control rod is connected to an actuator that can be eclectically or vacuum operated; by activating the actuator, all the flaps in the manifold move by the same amount. Note however, that the runner flaps never close off the runners completely; depending on the application, most systems only close off around 60% of the diameter of the inlet manifold runners.
To control and monitor the position of the manifold runner flaps, the PCM uses input data from the MAF (Mass Airflow) sensor, barometric pressure sensor, engine speed sensor, IAT (Intake Air Temperature) sensor, TPS (Throttle Position) sensor(s), and others to calculate an appropriate setting for the manifold runner flaps to suit current operating conditions. To be sure that the desired and actual positions of the runner flaps coincide, the PCM also uses input data from a dedicated position switch that communicates the actual position of the runner flaps to the PCM via a dedicated signal circuit.
From the above it should be obvious that effective communication between the PCM, the IMRC system actuator, and the IMRC system position switch is vital for the correct operation of the system, since IMRC flaps generally do not have a default open position. In practice, this means that if the system fails in the closed position, it will remain in that position until the failure is corrected.
Therefore, as soon as the PCM detects an intermittent loss of continuity in an electrical circuit that is directly associated with the IMRC position sensor/switch, or a failure of the position sensor itself that prevents effective communication between the PCM and the position sensor/switch, it will set code P2023 and illuminate a warning light.
Where is the P2023 sensor located?
The image above shows the typical appearance of an IMRC system, but note that in this instance, the system is operated by a vacuum controlled actuator, which is indicated by the yellow arrow. The green arrow indicates the electrical connector of the position switch, the red arrows indicate individual runner flaps, and the blue arrow indicates the linkage that connects the actuator to the control rod.
Note though that depending on the application, the actual design, appearance, layout, and arrangement of individual components may differ greatly from the example shown here. For this reason, it is important to refer to the manual for the affected application to locate and identify parts/components correctly- failure to do this will almost certainly result in confusion, wasted time, misdiagnoses, and the unnecessary replacement of parts and components.
What are the common causes of code P2023?
It should be noted that since code P2023 refers specifically to intermittent loss of electrical continuity in circuits that are directly related to the IMRC system position switch/sensor, or in the switch/sensor itself, it may sometimes be necessary to remove the inlet manifold to gain access to the position sensor/switch for the purposes of testing and/or replacement.
Nonetheless, some common causes of code P2023 could include the following-
- Poor electrical connections that are caused by damaged, burnt, shorted, disconnected, or corroded wiring and/or connectors
- Defective IMRC position switch
