P1936
Reading P1936 on your car
P1936 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1936
| Make | Fault Location |
| Ford | Fuel Level Signal |
| Land Rover | Clutch Switch/Sensor Signal |
| Lincoln | Fuel Level Signal |
| Mazda | Clutch Switch/Sensor Signal |
| Mercury | Fuel Level Signal |
We have not gotten around to publishing a technical guide specifically for P1936 yet.
