P1891
Manufacturer Specific Definitions for P1891
Buick | Throttle Position Sensor PWM Signal Low |
Cadillac | Throttle Position Sensor PWM Signal Low |
Chevrolet | Throttle Position Sensor PWM Signal Low |
Citroen | Transmission Transfer Case Contact Plate Ground Return Open Circuit |
Ford | Transmission Transfer Case Contact Plate Ground Return Open Circuit |
Gm | Throttle Position Sensor PWM Signal Low |
Kenworth | P1891 - Pre turbine pressure sensor out of range low |
Peterbilt | P1891 - Pre turbine pressure sensor out of range low |
Peugeot | Transmission Transfer Case Contact Plate Ground Return Open Circuit |
We have not gotten around to publishing a technical guide specifically for P1891 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
