P1876
Manufacturer Specific Definitions for P1876
Citroen | Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure |
Ford | Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure |
Kenworth | P1876 - Barometric pressure sensor out of range high |
Kenworth | P1876 - Ambeint air temperature sensor out of range low |
Lincoln | Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure |
Mercedes-Benz | CAN data bus, VSS signal – malfunction |
Mercury | Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure |
Mitsubishi | Gear Block 1st |
Peterbilt | P1876 - Barometric pressure sensor out of range high |
Peterbilt | P1876 - Ambeint air temperature sensor out of range low |
Peugeot | Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure |
Pontiac | Manual mode selection switch -circuit malfunction |
