P1875
Manufacturer Specific Definitions for P1875
Buick | 4WD Low Switch Circuit Electrical |
Cadillac | 4WD Low Switch Circuit Electrical |
Chevrolet | Transmission, 4WD low selection signal-circuit malfunction |
Citroen | Transmission Automatic Hall Effect Sensor Power Circuit Short To Battery / 4WD Low Switch Circuit Electrical |
Gmc | Transmission, 4WD low selection signal -circuit malfunction |
Gm | 4WD Low Switch Circuit Electrical (4L60-E Transmission) |
Hummer | Transmission, 4WD low selection signal -circuit malfunction |
Isuzu | AT – component slipping |
Kenworth | P1875 - Relative humidity sensor out of range low |
Mercedes-Benz | CAN data bus, transmission shift lever control module – malfunction |
Peterbilt | P1875 - Relative humidity sensor out of range low |
Peugeot | Transmission Automatic Hall Effect Sensor Power Circuit Short To Battery / 4WD Low Switch Circuit Electrical |
Suzuki | 4WD low gear position switch- circuit malfunction |
