P1864
Manufacturer Specific Definitions for P1864
Buick | Torque Converter Clutch Enable Solenoid Electrical Fault Conditions |
Cadillac | Torque Converter Clutch Enable Solenoid Electrical Fault Conditions |
Chevrolet | Torque Converter Clutch Enable Solenoid Electrical Fault Conditions |
Citroen | Transmission Transfer Case Contact Plate Power Short To Battery |
Daewoo | Eds 5 Drv Gnd Short |
Gmc | Torque converter clutch (TCC) solenoid -circuit malfunction |
Gm | TCC Enable Solenoid Electrical Fault Conditions |
Kenworth | P1864 - AFC slow learn compensation under range. |
Kenworth | P1864 - Upstream NOx sensor power-related data out of range fault |
Mitsubishi | High Side 1 System Short To Power Supply |
Peterbilt | P1864 - AFC slow learn compensation under range. |
Peterbilt | P1864 - Upstream NOx sensor power-related data out of range fault |
Peugeot | Transmission Transfer Case Contact Plate Power Short To Battery |
Pontiac | Torque Converter Clutch Enable Solenoid Electrical Fault Conditions |
Saturn | Torque Converter Clutch Enable Solenoid Electrical Fault Conditions |
We have not gotten around to publishing a technical guide specifically for P1864 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
