P1860
Manufacturer Specific Definitions for P1860
Acura | AT - torque converter clutch (TCC) solenoid |
Buick | TCC PWM Solenoid Circuit Electrical |
Cadillac | TCC PWM Solenoid Circuit Electrical |
Chevrolet | Torque converter clutch (TCC) solenoid -circuit malfunction |
Citroen | TCC PWM Solenoid Circuit Electrical/ Transmission Transfer Case Contact Plate "D" Short Circuit To Battery |
Gmc | Torque converter clutch (TCC) solenoid, pulsewidth modulation (PWM) -circuit malfunction |
Gm | TCC PWM Solenoid Electrical Fault |
Honda | AT - torque converter clutch (TCC) solenoid circuit |
Hummer | Torque converter clutch (TCC) solenoid, pulse width modulation (PWM) -circuit malfunction |
Isuzu | AT- torque converter clutch (TCC) solenoid circuit |
Kenworth | P1860 - Upstream NOx sensor O2 signal-related data not available fault |
Mercedes-Benz | CAN data bus, VSS signal, rear axle – malfunction |
Oldsmobile | Torque converter clutch (TCC) solenoid -circuit malfunction |
Opel | Torque converter clutch (TCC) solenoid - circuit malfunction |
Peterbilt | P1860 - Upstream NOx sensor O2 signal-related data not available fault |
Peugeot | TCC PWM Solenoid Circuit Electrical/ Transmission Transfer Case Contact Plate "D" Short Circuit To Battery |
Pontiac | Torque converter clutch (TCC) solenoid -circuitmalfunction |
Saab | Torque converter clutch (TCC) solenoid, pulse width modulation (PWM) – circuit malfunction |
Saturn | Torque converter clutch (TCC) solenoid -circuit malfunction |
