P1857
Manufacturer Specific Definitions for P1857
Audi | Load Signal Error Message From ECU |
Citroen | Transmission Transfer Case Contact Plate "C" Short Circuit To Ground |
Ford | Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground |
Kenworth | P1857 - Upstream NOx sensor NOx signal-related data out of range fault |
Lincoln | Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground |
Mercury | Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground |
Mitsubishi | Odd Number Gear Axle Interlock |
Peterbilt | P1857 - Upstream NOx sensor NOx signal-related data out of range fault |
Peugeot | Transmission Transfer Case Contact Plate "C" Short Circuit To Ground |
Volkswagen | Load Signal Error Message From ECU |
