P1847
Manufacturer Specific Definitions for P1847
Buick | 2-3 Shift Solenoid Circuit High Input Voltage |
Cadillac | 2-3 Shift Solenoid Circuit High Input Voltage |
Chevrolet | 2-3 Shift Solenoid Circuit High Input Voltage |
Citroen | Transmission Transfer Case Contact Plate "A" Open Circuit |
Gm | 2-3 Shift Solenoid Circuit High Input (4T80-E Transmission) |
Kenworth | P1847 - Upstream NOx sensor ECU-ID message low rate fault |
Opel | Transmission control module (TCM),multiplexing - no signal |
Peterbilt | P1847 - Upstream NOx sensor ECU-ID message low rate fault |
Peugeot | Transmission Transfer Case Contact Plate "A" Open Circuit |
Pontiac | Gear shift, 2-3 -malfunction |
Saturn | 2-3 Shift Solenoid Circuit High Input Voltage |
