P1846
Manufacturer Specific Definitions for P1846
Citroen | Transmission Transfer Case Contact Plate "A" Circuit Failure |
Ford | Transmission Transfer Case Contact Plate 'A' Circuit Failure |
Infiniti | Automatic Transmission Fluid Pressure Switch 6 |
Kenworth | P1846 - Upstream NOx sensor ECU-ID message high rate fault |
Nissan | Automatic Transmission Fluid Pressure Switch 6 |
Peterbilt | P1846 - Upstream NOx sensor ECU-ID message high rate fault |
Peugeot | Transmission Transfer Case Contact Plate "A" Circuit Failure |
