P1845
Manufacturer Specific Definitions for P1845
Buick | Torque limit management |
Cadillac | Torque limit management |
Chevrolet | 2-3 Shift Solenoid Circuit Low Input Voltage |
Citroen | Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground |
Gm | 2-3 Shift Solenoid Circuit Low Input (4T80-E Transmission) |
Infiniti | Automatic Transmission Fluid Pressure Switch 5 |
Kenworth | P1845 - Upstream NOx sensor compatibility monitor fault |
Nissan | Automatic Transmission Fluid Pressure Switch 5 |
Opel | Transmission ratio monitor - circuit malfunction / AT torque control,signal - malfunction |
Peterbilt | P1845 - Upstream NOx sensor compatibility monitor fault |
Peugeot | Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground |
Pontiac | Gear shift, 2-3 -malfunction |
Saturn | Engine control module (ECM), torque management -torque higher than expected |
