P1842
Manufacturer Specific Definitions for P1842
Buick | 1-2 Shift Solenoid Circuit Low Input Voltage |
Cadillac | 1-2 Shift Solenoid Circuit Low Input Voltage |
Chevrolet | 1-2 Shift Solenoid Circuit Low Input Voltage |
Citroen | Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure |
Gm | 1-2 Shift Solenoid Circuit Low Input (4T80-E Transmission) |
Kenworth | P1842 - Upstream NOx sensor AT1IGC2 low rate fault |
Opel | Throttle position (TP) sensor signal out of range |
Peterbilt | P1842 - Upstream NOx sensor AT1IGC2 low rate fault |
Peugeot | Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure |
Pontiac | Gear shift, 1-2 -malfunction |
Saturn | 1-2 Shift Solenoid Circuit Low Input Voltage |
We have not gotten around to publishing a technical guide specifically for P1842 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
