P1841
Manufacturer Specific Definitions for P1841
Buick | Internal Mode Switch 'S' Circuit High Voltage |
Cadillac | Internal Mode Switch 'S' Circuit High Voltage |
Chevrolet | Internal Mode Switch 'S' Circuit High Voltage |
Citroen | Transmission Transfer Case Shift Motor Short Circuit To Ground |
Daewoo | Eds 3 Drv Crct Open |
Gm | Internal Mode Switch 'S' Circuit High Voltage |
Infiniti | Automatic Transmission Fluid Pressure Switch 1 |
Kenworth | P1841 - Upstream NOx sensor AT1IGC2 high rate fault |
Nissan | Automatic Transmission Fluid Pressure Switch 1 |
Peterbilt | P1841 - Upstream NOx sensor AT1IGC2 high rate fault |
Peugeot | Transmission Transfer Case Shift Motor Short Circuit To Ground |
