P1840
Reading P1840 on your car
P1840 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1840
BuickInternal Mode Switch 'S' Circuit Low Voltage
CadillacInternal Mode Switch 'S' Circuit Low Voltage
ChevroletInternal Mode Switch 'S' Circuit Low Voltage
CitroenTransmission Transfer Case Shift Motor Short Circuit To Battery
DaewooEds 3 Drv Crct Batt Short
FordTransmission Transfer Case Shift Motor Short Circuit To Battery
GmInternal Mode Switch 'S' Circuit Low Voltage
KenworthP1840 - Upstream NOx sensor AT1IGC1 low rate fault
LincolnTransmission Transfer Case Shift Motor Short Circuit To Battery
MercuryTransmission Transfer Case Shift Motor Short Circuit To Battery
PeterbiltP1840 - Upstream NOx sensor AT1IGC1 low rate fault
PeugeotTransmission Transfer Case Shift Motor Short Circuit To Battery
We have not gotten around to publishing a technical guide specifically for P1840 yet.
